Speedometer glass
  • martin_csr
  • martin_csr's Avatar Topic Author
Speedometer glass
31 Aug 2019 10:55 - 31 Aug 2019 16:19
#810148
needed glass dimensions: 96mm diameter x 1.72mm thickness.
Is there a source for replacement speedometer glass for 80s meters? I looked for round glass on EB. Then I had some 1/16" glass cut locally, which should have been too thin, but it's actually too thick >> it was 2.20 mm, which is closer to 3/32".
1/16 = 1.5875mm ... 5/64 = 1.98mm ... 3/32 = 2.38mm
Last edit: 31 Aug 2019 16:19 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
  • Busy
Re: Speedometer glass
31 Aug 2019 17:04
#810164
Z1 Resto?
  • martin_csr
31 Aug 2019 18:20 - 31 Aug 2019 18:22
#810168
AFAIK, they only do 70s meters. I think the glass on those is about 92mm. CB750faces.com has glass but only 79mm & 92mm.
Last edit: 31 Aug 2019 18:22 by martin_csr.
