1979 kz1000b3 ltd
- FinnGoy
1979 kz1000b3 ltd
18 Jul 2019 15:28
My kz is having issue starting. The starter cranks once but all my light still work so I don’t think it’s bad battery and it’s a new one to. I thinking it has to do with the stator I’m pretty new to working on bikes so I’m learning as I go so I’m now learning how a stator works. cause it could be wiring from stator to I don’t know exactly what issue is. Does anyone have any input what to do or what to buy?
Re: 1979 kz1000b3 ltd
18 Jul 2019 16:18
If it was mine I would start by having the battery tested to ensure it is ok - especially since it is new. Ed
19 Jul 2019 06:05
Definitely have the battery load tested. Even a new one can be bad. If there is an internal short, the battery can show correct voltage, but not have enough apmerage to start the bike.
Also, be very sure that both ends of the negative battery cable have clean, tight connections.
- Greybeard
19 Jul 2019 07:32
Sounds like a bad battery cable to me.
1982 KZ1100 D-1
