Relay mod for powering coils question...
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
03 Jul 2019 10:44
#806915
If I run a relay to (key on) power my coils, what should be done with the previous 2 factory red wires? Thanks!
1982 KZ1100D1
  • Nessism
  • Nessism's Avatar
Re: Relay mod for powering coils question...
03 Jul 2019 16:40
#806926
I thought the idea was to use the red coil wires, which get switched power through the ignition switch, as the trigger to turn on the relay and feed power straight from the fuse box?
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Jul 2019 19:17
#806932
On the larger fours it's yellow and red stripe.
  • Warren3200gt
  • Warren3200gt's Avatar
03 Jul 2019 21:31 - 03 Jul 2019 21:33
#806933
Connect to the wire drawn in red on the diagram below.
Last edit: 03 Jul 2019 21:33 by Warren3200gt.
