Z1R tail light out
  • bille7
  • bille7's Avatar Topic Author
Z1R tail light out
23 Jun 2019 05:40
#806298
So my '78's headlight gradually dimmed, signals began blinking really slow, and it began fouling plugs. It was past time to clean all of the connections and check for wiring issues. Had been putting off doing something with the cheesy 3-fuse housing that usually melts around the main fuse connection so I pulled and replaced it with a 4-slot ATM fuse setup (it can be reinstalled as I used the same type of pigtail connector) with a relay to "upgrade" the Dyna ignition . Haven't started the motor yet but after cleaning most of the electrical connections- the lights appear to working normally again. As I began reassembling it, I noticed the tail light was out. There is no power to that connector (red/white wire) just in front of the tail light . The brake, head, and running lights work and if the 3 prong headlamp connector is pulled, the "Headlamp" indicator lights as intended but the "tail/brake" light indicator does not . The brake light functions normally. There is power to both sides of the TAIL fuse so am going to begin tracing the connection back. I'd love to bypass the Aux Lighting Unit but don't want to mess things up and create a small disaster. Before I begin pulling things apart, was hoping to get input from anyone who may have dug in deeper than just cleaning the connectors.
thanks in advance and hope the rest of the weekend is good-
Re: Z1R tail light out
23 Jun 2019 06:34
#806302
How old is the battery? Ed
  • bille7
23 Jun 2019 07:16
#806307
I wish it was something like that! It has a Shorai bat "currently" putting out 13.6 volts.
thanks-
hoping the rest of the weekend is fun!
gonna work on this another couple of hours then mow and hopefully go riding around 2pm or so-
b
  • martin_csr
  • martin_csr's Avatar
23 Jun 2019 08:20
#806315
Do you have a wiring diagram for the motorcycle? Often times there's a red power wire from the ignition switch to the tail light, so the problem could be with the ignition switch. maybe a soldered connection has failed. ???
  • bille7
23 Jun 2019 09:31
#806320
Yeah I have one and already THOUGHT I posted that it was fixed but was evidently in a hurry and must've missed an error msg after I hit the 'Submit" icon.
c'est la vie. I'm gonna de-activate my profile from KZride. You shouldn't have to check a bunch of traffic light or crosswalk boxes just to send a post...
anyhow yes it is fixed and thanks for chiming in! much appreciated!
