Stop Lamp Flashing
  • Deadulus
  • Deadulus's Avatar Topic Author
Stop Lamp Flashing
21 Jun 2019 13:55
#806228
Hey you guys. What does it mean when you turn the key on and the STOP lamp flashes? Its a '78 KZ650C.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Stop Lamp Flashing
21 Jun 2019 14:04 - 21 Jun 2019 14:05
#806229
Your brake light bulb is shot or disconnectet from the wiring harness.
Last edit: 21 Jun 2019 14:05 by Scirocco.
The following user(s) said Thank You: Deadulus
  • Deadulus
21 Jun 2019 22:48
#806245
Well....now that's obvious. It is sitting on my bench and the bike is outside :P
22 Jun 2019 05:12
#806251
The flashing is a warning that next time either or both brakes are applied, that the rear brake light will not illuminate as it's supposed to.
A missing rear bulb is only one of several possible causes of rear brake light failure.
Good Fortune! :)
