Wiring diagram HELP. Which side of coils is ground??
  • chopper1963
  • chopper1963's Avatar Topic Author
09 Jun 2019 12:34
#805420
Summer is here and I'm trying to finish my 1981 GPz550. Right now I am putting the new Kawi coils on it and forgot to take a pic when I took the old ones off. Does anyone know which side of each coil connection in front is power and which is ground? I THINK on both sides and both coils power (red/yellow wire) is on the outside and ground is inside. Is this correct? Kawi manual is kind of ambiguous. Any suggestions?
  • loudhvx
  • loudhvx's Avatar
Re: Wiring diagram HELP. Which side of coils is ground??
09 Jun 2019 12:52
#805423
Even though the factory coils have + and - labels, it really doesn't matter.
If you still have factory coils you can see a + and - mark on them if you want to stick with their markings.
The following user(s) said Thank You: chopper1963
  • chopper1963
11 Jun 2019 05:28
#805500
Thanks. I put on my cheaters and indeed there is a microscopic + and - on the coils.
  • martin_csr
  • martin_csr's Avatar
11 Jun 2019 05:55 - 11 Jun 2019 05:55
#805501
Yes, the markings are kind of small & on the 81 650 they're facing inward, so a guy wouldn't see them without removing the coils.
From the 1981 KZ650 FSM.
Last edit: 11 Jun 2019 05:55 by martin_csr.
