grounding
- rudof88
grounding
29 Apr 2019 14:02
is the headlight bucket a good grounding source? wanna know before i screw somthin up
1981 kz 650 csr
- Warren3200gt
Re: grounding
29 Apr 2019 14:09 - 29 Apr 2019 14:10
The shell itself is rubber mounted by the indicator mounts. So it is not earthed. You could use the headlight bulb earth or the indicator earths.
Last edit: 29 Apr 2019 14:10 by Warren3200gt.
Re: grounding
29 Apr 2019 15:22
I have the same motorcycle. There should be an accessory ground inside the headlight bucket.
There also should be an accessory power wire there as well >> blue-white wire.
Not sure what you're trying to do, but I moved the turn signals from the handlebars to the headlight bucket by installing turn signal stems in place of the big headlight bolts & I replaced the tiny turn signal grounding rings w 10mm rings to fit the turn signal stems.
