Wiring kz400
- FJR1
19 Apr 2019 09:02 #802410
by FJR1
Wiring kz400 was created by FJR1
Hello guys, I am redoing the wiring on my kz 400 and was wondering were is the best place online to get all the material, I am looking to use the same colors codes for the wires. Thank you for the help!
- Thank you received: 1656
19 Apr 2019 15:19 - 19 Apr 2019 15:19 #802433
by martin_csr
Replied by martin_csr on topic Wiring kz400
Z1Enterprises.com has colored wire, connectors & terminal pins. probably some other stuff.
CycleTerminal has a good selection of connectors, terminals pins, etc., including some waterproof bullet connectors.
To crimp the terminal pins you'll need an open barrel crimper >> the crimps are very strong. Get extra terminal pins for practice or in case you mess up. I got most of my stuff from cycleterminal. I already had a HF ratcheting crimper, but the dies were wrong, so I got a set of open barrel dies on amazon.com. Cycle terminal has a crimper that costs about what I ended up spending.
Last edit: 19 Apr 2019 15:19 by martin_csr.
The following user(s) said Thank You: FJR1
