Plug caps
- Kwaka1977
Plug caps
26 Mar 2019 02:59
Hi guys
Having issues finding the 120 degree angle plug caps. Has anyone had success in replacing with straight plug caps?
Matt
Matt
Re: Plug caps
26 Mar 2019 05:25
- Jussumguy
Re: Plug caps
26 Mar 2019 05:48
Wow there they are. Is there a certain resistance to look for?
- old_kaw
Re: Plug caps
26 Mar 2019 11:57
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Often it helps to note exactly what year and model you are working on, although I am assuming it is a Kawasaki motorcycle. I am pretty clairvoyant, sooo for example my 81 Kz1000K1 takes the NGK XB05F on the 2 inner cylinders and the NGK LB50F on the outer two cylinders. Here are two fleabay links, both with free shipping. They are 5K resistance with solid copper plug wires.
(2) inner:
(2) Outer:
Jussumguy wrote: Wow there they are. Is there a certain resistance to look for?
(2) inner:
(2) Outer:
1981 Kawasaki Kz1000K1
The following user(s) said Thank You: Jussumguy
