81 ltd 750 wont turn over
- CDgomez1985
25 Mar 2019 20:05
so i posted before and getting discouraged ....my bike wont turn over brand new battery ,tested starter it works.brand new solenoid.it would turn over before now get nothing .......checked all the connections im thinking ill just sell it
Re: 81 ltd 750 wont turn over
25 Mar 2019 21:09
It may be something fairly simple. Have you considered simply taking it to a shop and letting a pro diagnose the problem? Ed
- M_a_t_t
26 Mar 2019 07:52
Can you turn the engine over by hand (with a wrench)? Does it do nothing at all? Finally, does it have a kickstarter?
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
- Warren3200gt
26 Mar 2019 08:13
Does it turn over if you breach the solenoid poles?
26 Mar 2019 08:13 - 27 Mar 2019 05:30
Assuming the motorcycle is a KZ750-H2 4-cylinder, it shouldn't have a kick-starter (unless someone installed one).
When pressing the start button, does the starter solenoid click or anything?
I would check the battery with a digital multimeter & do a load test. Never assume a battery is good >> test it. New batteries are known to be bad or go bad if not properly serviced before installing it. If the battery checks out after charging with a good motorcycle smart charger, then I'd test for voltage at the starter solenoid. If you're getting voltage at the fat starter cable, then I'd make sure the connection is good at the other end of the fat cable, at the starter.
Last edit: 27 Mar 2019 05:30 by martin_csr.
