Electrical "damage"
- Trackerkz650sr
- Banned
Electrical "damage"
20 Mar 2019 14:44
Just curious what kinda ill effects or damage i may want to look into
If anyone has had this issue
Basically my regulator was overcharging and i failed to fix it and rode anyways
Ride was good for about 10 miles
Until i decided to rev the motor and my lights cut out
Now all my lights are dead (took them off individually and put battery power to them)
Bike runs and is still overcharging
So i will replace the regulator
However im curious.
Is it possible my battery is f'd also even tho it reads 12 .36v?
And is it possible the stator or points got damaged from excess voltage?
Last question is how come none of the fuses blow when a regulator is kickin that much juice to lights?
However im curious.
Re: Electrical "damage"
20 Mar 2019 15:41 - 20 Mar 2019 15:58
If you run more than 14 Volts over a longer time you will boil vaporised your battery acid and other electric divices can be destroyed.
Your fuses blown only by the specific current (Ampere) limit not the voltage ( Volt) = you got a short cut near Zero resistent (Ohm).
Ohms Law : U (Voltage V ) = R (Ohm Ω ) * I (Current (A)mpere)
I = U / R
R = U / I
P (W)att) = U * I = 12 Volt * 1,75 Ampere = 21 Watt for a single turning light bulb
I = U / R
R = U / I
Last edit: 20 Mar 2019 15:58 by Scirocco.
The following user(s) said Thank You: Trackerkz650sr
- loudhvx
21 Mar 2019 08:35
Fuses protect the wiring against a short-circuit causing a huge increase in current, which would melt wiring.
Fuses do not protect against over-voltage causing a slight increase in current, which does not melt wiring (but may destroy lights and other components).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Trackerkz650sr
- Banned
- gordone
22 Mar 2019 16:13
I have heard IC ignition unit don’t like over voltage, cross fingers its still okay.
Project:
Project:
- Trackerkz650sr
- Banned
25 Mar 2019 11:35
Got a three wheeler regulator on it and all is well. Except all the leds. Guess they didnt like 17+ volts lol
- gordone
25 Mar 2019 14:47Trackerkz650sr wrote: Got a three wheeler regulator on it and all is well. Except all the leds. Guess they didnt like 17+ volts lol
Hehe good chance replace some old leds
Project:
Project:
