Voltage drop issues
  • ZoomsJr
  • ZoomsJr's Avatar Topic Author
Voltage drop issues
19 Mar 2019 15:01
#800665
To start, I’ve cleaned just about every connection I can see under the tank and behind the headlight, checked engine ground, replaced the ignition switch, cleaned the kill switch etc etc. The problem is that without the ignition on, the white wire to the switch gets battery voltage. However, as soon as the ignition is switched on the voltage to the same white wire drops to 2.5-3V. Anyone have any ideas?
1978 KZ650 B2A
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Voltage drop issues
19 Mar 2019 16:02
#800669
Could be the load after the switch or a wire that has been overloaded and is acting as a resister due to being overheated.
  • Warren3200gt
  • Warren3200gt's Avatar
19 Mar 2019 16:21
#800670
Or even the ignition switch itself. A few weeks back I had a solder joint on an aftermarket ignition switch fail and break. A bad soldered connection would cause resistance. It was an easy fix on mine, but not by the roadside :angry:
  • ZoomsJr
19 Mar 2019 17:45
#800683
SWest wrote: Could be the load after the switch or a wire that has been overloaded and is acting as a resister due to being overheated.
Thanks for the idea Steve, what the best way to figure out which wire may be acting as a resistor is this is the case?
Also I forgot to mention the the ignition switch is brand new
1978 KZ650 B2A
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Mar 2019 18:44
#800692
With my 40 year old loom I ran a new white and brown wire. In the wreck the white wire was toast so I combined a KZ 900 loom and ran it in 87. Because of old/bad connections I had to change switches and loom again.
  • Warren3200gt
20 Mar 2019 04:46
#800707
ZoomsJr wrote: Also I forgot to mention the the ignition switch is brand new
As was mine, someone should teach the Chinese to solder!
  • loudhvx
  • loudhvx's Avatar
20 Mar 2019 06:07
#800711
Besides the switch,. a very common place to lose voltage is at the fuse holders. They get dirty and start to have resistance. See if the wires in the fuse box look burned or melted.
  • ZoomsJr
20 Mar 2019 07:51
#800717
Fuse box is brand new as well, old one melted around the main fuse. I believe the previous owner had a 25A fuse instead of a 20 for the main,
1978 KZ650 B2A
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Mar 2019 07:59
#800718
Check your grounds too.
  • ZoomsJr
20 Mar 2019 08:20
#800722
SWest wrote: Check your grounds too.
Cleaned (sprayed and buffed) the engine ground but I still have .5-1 ohm resistance on the case with a super cheap multimeter
1978 KZ650 B2A
  • Warren3200gt
20 Mar 2019 08:20 - 20 Mar 2019 08:21
#800723
ZoomsJr wrote: Fuse box is brand new as well, old one melted around the main fuse. I believe the previous owner had a 25A fuse instead of a 20 for the main,
Fuse box as in the plastic case? Its the fuse connectors that need checking and cleaning unless it came with anew loom bit as well?
Last edit: 20 Mar 2019 08:21 by Warren3200gt.
  • ZoomsJr
20 Mar 2019 09:08
#800725
The new fuse box is the one from z1 which includes the plastic case, fuses, as well as the pigtail and red/white striped wire and white wire with bullet connectors
1978 KZ650 B2A
