Refurbishing meters
  • martin_csr
  • martin_csr's Avatar Topic Author
Refurbishing meters
18 Mar 2019 07:34 - 18 Mar 2019 07:40
#800562
How would you clean the face of a speedometer? I've already disassembled the speedo and have wiped the face with a clean damp microfiber cloth. There are a few minor spots, nothing significant. I may try good ole' dawn dishwashing liquid or simple green, unless someone found something that works great.
Also, does anyone know if there's a good spray paint match for the green liner?
Krylon & Rustoleum have some colors that're a close match, but kind of too light.
The liner has been separated from the black housing & the gaskets are soaking in LW silicone spray.
1981 KZ650-CSR speedometer.
Last edit: 18 Mar 2019 07:40 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Refurbishing meters
18 Mar 2019 07:41
#800564
I use rubbing alcohol to clean them.
  • martin_csr
18 Mar 2019 07:49 - 18 Mar 2019 07:53
#800566
Okay. The face is in pretty good condition, so I was hesitant to try rubbing alcohol or any solvents.
A junk meter would be handy for experimenting. A few years back I kind of went overboard collecting extra parts
but didn't happen to get a useless speedo or tach. I've got plenty of other useless junk. :laugh:
Last edit: 18 Mar 2019 07:53 by martin_csr.
  • davido
  • davido's Avatar
18 Mar 2019 08:45 - 18 Mar 2019 08:47
#800575
For cleaning, I used the spray for cleaning the dashboard of your car. Came up a treat. Dont know what its called though.
(Dont know what dashboard is in Americanish!)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 18 Mar 2019 08:47 by davido.
  • martin_csr
18 Mar 2019 09:39 - 19 Mar 2019 07:42
#800578
Same as you, dashboard! So, do you mean a general purpose interior cleaner or something specific for the dashboard?
Liner paint. Rustoleum Satin Vintage Teal appears to be a very close match >> painter's touch 2x ultra cover paint+primer.
Krylon colormax satin sea glass is also close >> maybe too light but probably not that noticeable.
Last edit: 19 Mar 2019 07:42 by martin_csr.
  • Warren3200gt
  • Warren3200gt's Avatar
18 Mar 2019 10:26
#800580
I use this stuff on anything black, brilliant stuff for brake hose, radiator hose, bike seats, engine black paint, pretty much anything you want returning to black. It has no pigment so will not cover the lettering on the face but will return the face to unmarked black.
Not sure if you can get it in the US but worth a try.
shop.cannontools.co.uk/car-valeting-prod...666-115-15751377.php
  • davido
  • davido's Avatar
18 Mar 2019 14:05
#800586
I think the stuff I used was called 'Cockpit spray' but it looks like the stuff Warren is using. Good on anything black. From a car shop (?) . I also found a can of 'Tyre Magic" and tried that on a bit of plastic. Came up nice. Anything for car interiors would probably do you.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • JR
  • JR's Avatar
19 Mar 2019 09:50
#800638
Stay away from solvents. I accidentally picked up contact cleaner when I reached for the dustbuster spray.
The result was not good :sick:
  • martin_csr
21 Mar 2019 05:49 - 21 Mar 2019 10:27
#800774
The speedo face is in pretty good condition, so that'll have to be good enough after cleaning with plain water. Going in, I knew restoring the speedometer was going to be problematic because there are no parts available. Everything has to be re-used & probably the biggest unknown right now is the rubber gaskets as one is still stretched & needs more cleaning. I soaked them for several days in silicon, but there's still hardened crud that'll need to be removed from the top gasket. I boiled them in water to shrink them, which worked on the bottom gasket but not the top gasket which is thicker, so it may need more boiling time. or it may just be shot.
I used Krylon satin sea glass on the inner liner. Rustoleum satin vintage teal is another option. To the naked eye the Krylon color looks almost the same as the green plastic bottom housing cover, but in digital pics it's lighter. I think the rustoleum vintage teal would be darker, so I chose Krylon. someone else might prefer another color.
Duplicolor gloss black engine paint. Speedo glass looks crystal clear but has fine scratches.
Last edit: 21 Mar 2019 10:27 by martin_csr.
  • davido
  • davido's Avatar
21 Mar 2019 12:07
#800786
For restoring hardened rubber parts,try 'winter green'. No idea what its called by you but I bought it at the chemist (drugstore?). It was recommended to restore and soften the inlet rubbers. ( another article in Practicle sportsbike magazine. The same magazine as the clock restoration article) You are meant to boil them in it but as it smells so strongly,I wiped them down,sealed them in a plastic bag and put them away somewhere 'safe'. That must be at least 5 years ago,and I still havent found them. I ended up buying new ones!!!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • martin_csr
21 Mar 2019 12:27
#800788
Thanks. Pharmacies or drug stores here often times carry wintergreen oil. If new gaskets were available, that's what I'd do. The earlier meters are different & have different measurements, so I don't think those gaskets would fit.
  • jayrodoh
  • jayrodoh's Avatar
21 Mar 2019 16:43
#800799
I've always used Windex on a soft cloth for cleaning parts like that. Goes on a Q-tip well too. Never had an issue with it removing paint etc. on gauges and other items.
Nice attention to detail, I can dig it.
1982 KZ750-M1 CSR
