Weird electronic ignition?!
  • Trackerkz650sr
  • Trackerkz650sr's Avatar Topic Author
  • Banned
  • Banned
03 Mar 2019 11:39
#799601
Hey yall. Im new here but had an account in the past
Looking to see if u guys can educate me on this electronic ignition
Im familiar with dyna not this one. Bought it used from a kz fanatic here in town.
Hoping its actually from a kz650
Will these coils and ignition work ok?
And is using points with these accell coils worth it or is the stock just fine?
Thanks guys!!
  • Nessism
  • Nessism's Avatar
Re: Weird electronic ignition?!
03 Mar 2019 13:02
#799608
The stock coils are high quality and have the proper resistance to work with the whatever type of ignition Kawasaki put on your bike stock. Points ignition system coils have more resistance than those of the coils that came with the electronic ignition fitted later. If you want to use those Accel coils you should check resistance and make sure they are compatible with your bikes needs. You may need a ballast resistor.
  • Trackerkz650sr
  • Banned
  • Banned
03 Mar 2019 17:14
#799641
Understandable.
I do know stock coils work with electronic ignition.
What im mainly curious about is what brand ignition is this
Only stamp says kw. Doesnt look exactly like the dyna
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
04 Mar 2019 13:41
#799701
I'm pretty sure that's the trigger plate from the Dyna III ignition. I have one on my bike, but I haven't looked at it in a number of years.
www.midwesttraction.com/store/c265/ignit...cycle-street--d37-1/
www.powercommander.com/downloads/Support...nuals/D32-1_32-2.pdf
If it is a Dyna III, it's just a trigger. You need the igniter box to make it work. Also, you need the rotor with magnet to complete the trigger assembly (this replaces the points cam on the advancer).
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: Scirocco
  • loudhvx
  • loudhvx's Avatar
04 Mar 2019 13:46 - 04 Mar 2019 13:52
#799702
Yes, like DOHC said, it's a Dyna III. It's the predecessor to the Dyna S. That particular plate is for inline-four Kz400/500/550/650/700/750 motors.
The Dyna III requires a Dyna III igniter box to control the coils. That plate only has pickups.
It also requires a Dyna III rotor with a permanent magnet embedded in it. I think a rotor from a Dyna S might also work with the Dyna III, at least there is a chance of it.
I believe the Dyna III might require 3 ohm or higher coils just as the Dyna S requires. Stock points-coils should work fine with that ignition. Stock points coils are nominally 4 ohms.
The coils in your photos are most likely 3 ohm Accel coils. (You should measure them to be sure.) They can work temporarily with points, but will accelerate point wear. They would work fine with either the Dyna S or Dyna III and a factory electronic ignition as well.
You should not use factory electronic ignition coils with the Dyna S or Dyna III. The factory electronic coils are nominally 2.3 ohms.
Last edit: 04 Mar 2019 13:52 by loudhvx.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
04 Mar 2019 14:08
#799706
The Dyna III pickup plate and igniter box should look like this
  • Trackerkz650sr
  • Banned
  • Banned
07 Mar 2019 15:46
#799892
Man u guys rock i appriciate that info
So basically i want to get the dyna s.
Id prefer not to have the ignitor box.
Just more shit to break lol
  • DOHC
  • DOHC's Avatar
07 Mar 2019 19:35
#799909
The Dyna S is a good product, but before we can recommend a solution we need to know what specific year and model you want to put it on. :)
My dad's '74 Z1
'00 ZRX1100
  • zed1015
  • zed1015's Avatar
08 Mar 2019 02:56
#799917
Trackerkz650sr wrote: So basically i want to get the dyna s.
Yes! just get a Dyna S.
No ignitor box needed.
Fit and forget.
It will work with stock or performance coils with enough spark to light a bucket of piss.
The following user(s) said Thank You: old_kaw
  • DoctoRot
  • DoctoRot's Avatar
08 Mar 2019 13:11
#799948
those Accel coils are pretty nice. 140403 is the 3 ohm coil. I have them on my GSXR. The only thing is they are prone to rust on the spark plug wire terminals
  • old_kaw
  • old_kaw's Avatar
08 Mar 2019 15:20 - 08 Mar 2019 15:20
#799958
zed1015 wrote: It will work with stock or performance coils with enough spark to light a bucket of piss.
Tanks alot Zed! I almost spit my coffee all over my notebook while glancing through this thread!
And exactly how much voltage does it take to light a bucket of piss? :woohoo:
Inquiring minds want to know. lol
1981 Kawasaki Kz1000K1
Last edit: 08 Mar 2019 15:20 by old_kaw.
