KZ 1000 1979
  • JPAULOCOUPE
  • JPAULOCOUPE's Avatar Topic Author
KZ 1000 1979
27 Feb 2019 05:50 - 27 Feb 2019 09:55
#799303
hello
i need help because I'm not sure if the connection is well made.
Can someone confirm me if it's okay?
1-2
2-3
3-4
4-1
best regards...
Last edit: 27 Feb 2019 09:55 by JPAULOCOUPE.
  • TexasKZ
  • TexasKZ's Avatar
Re: KZ 1000 1979
27 Feb 2019 06:01
#799304
What connection are you asking about?
  • JPAULOCOUPE
Re: KZ 1000 1979
27 Feb 2019 06:04
#799307
the connect coil to cilinder head (spark)
Re: KZ 1000 1979
27 Feb 2019 06:07 - 27 Feb 2019 06:08
#799308
Good Fortune! :)
Last edit: 27 Feb 2019 06:08 by Patton.
  • TexasKZ
  • TexasKZ's Avatar
Re: KZ 1000 1979
27 Feb 2019 06:11 - 27 Feb 2019 06:12
#799310
If the wiring is factory correct, the left coil is connected to 1 and 4, the right coil is connected to 2 and 3.
And Patton is faster than I am.
Last edit: 27 Feb 2019 06:12 by TexasKZ.
Re: KZ 1000 1979
27 Feb 2019 06:13 - 27 Feb 2019 06:14
#799311
Good Fortune! :)
Last edit: 27 Feb 2019 06:14 by Patton.
The following user(s) said Thank You: TexasKZ
  • TexasKZ
  • TexasKZ's Avatar
Re: KZ 1000 1979
27 Feb 2019 06:14
#799312
  • JPAULOCOUPE
Re: KZ 1000 1979
27 Feb 2019 06:27
#799314
sorry i dont put images but now is ready
  • JPAULOCOUPE
Re: KZ 1000 1979
27 Feb 2019 07:21
#799325
hi
this case my images is worng... i need to change.
best regards
Re: KZ 1000 1979
27 Feb 2019 07:56
#799329
In stock configuration:
Port-side coil (coil on the left-hand side when sitting on the bike) goes to outside spark plugs;
Starboard-side coil (coil on the right-hand side when sitting on the bike) goes to inside spark plugs.
What are colors of the two small wires that attach to each coil's primary terminals? This will help us to be sure that the signal (trigger) wires haven't been mixed so as to have the left coil fire inside plugs and the right coil fire outside plugs (which will work, but isn't stock).
Good Fortune! :)
  • JPAULOCOUPE
Re: KZ 1000 1979
27 Feb 2019 08:11
#799332
hi will check the colors and after i tell you
best regards
  • JPAULOCOUPE
Re: KZ 1000 1979
27 Feb 2019 08:40
#799334
left side
1 - red
2 - black
right side
1 - red
2 - green
