ABS brake upgrade
  • gordone
  • gordone's Avatar Topic Author
ABS brake upgrade
30 Jan 2019 03:55
#797893
Is there anybody have experience upgrade to ABS brake/brakes?
Project:
  • M_a_t_t
  • M_a_t_t's Avatar
Re: ABS brake upgrade
30 Jan 2019 06:50
#797898
I haven't, but if you were to try it would be a lot easier to swap in wheels from a newer bike with abs. There is a reluctor ring in the rotors to track wheel speed. Then you would have to mount the sensor and run new brake line. I believe the ABS on my new bike is all housed in one unit so as long as you found somewhere to put the assembly it should work.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
  • KZB2 650
  • KZB2 650's Avatar
31 Jan 2019 07:02
#797964
I was all ready to buy a new 06 ZZR600 but decided against it since in the 3 or 4 panic stops I've had over the years I clamped onto the front lever so hard I would a ended up flipping it before I had time to react......... I tore the skin behind my knuckles one of those times clamping so hard ..... went around a sharp corner on my dirt bike expecting the usual jump and the guys had went in there with a bobcat and turned it into a 6 or 7 foot sheer drop off...... that one hurt as I wasn't ready.:blush:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • gordone
31 Jan 2019 13:21 - 31 Jan 2019 13:21
#797986
ABS brake is maybe for chickens? Heh
Always fun to look into upgrades and what is possible for future works :)
Project is never ending fun for me I think :)
Project:
Last edit: 31 Jan 2019 13:21 by gordone.
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 Jan 2019 13:46
#797992
I've panic stopped in sand in a Ford Excursion. The pedel vibrated so bad I had to let off and reapply the brakes. Retrofitting a modern system gives me the Willies. A lot of engineering and R/D goes into those systems. I'd rather rely on my skills than find out I made a miscalculation costing injury or my life.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
31 Jan 2019 14:45 - 31 Jan 2019 14:45
#797993
In my own personal opinion, unless you ride wrecklessly, to me the ABS is not an 'upgrade" but a nuisance. More complications and things to breake and maintain. My old truck has it in the rear wheels,... I have disabled it. Only useful if driving on the snow.
Last edit: 31 Jan 2019 14:45 by hugo.
