Short Stem Signal Lights for KZ650
- z1kzonly
Re: Short Stem Signal Lights for KZ650
25 Jan 2019 13:22
No eBay APP ID and/or Cert ID defined in Kunena configurationIt looks like front blinkers are shorter?
I never had of built 650's?
- 650Dude
- Banned
25 Jan 2019 13:26
Im not sure if front and rear are interchangeable?
z1kzonly wrote: It looks like front blinkers are shorter?
1977 Kawasaki KZ650B
1977 Kawasaki KZ750 Twin
25 Jan 2019 15:08 - 25 Jan 2019 15:18
By 650Dude: yeah, I was about to say they wont fit. The triangular shaped part doesnt fit in the mounting hole on the bike....
Check your turn signal stems & turn signal frame mounts. The turn signals may have a diamond-shaped plastic piece that fits into a rubber damper that has a diamond-shaped hole, and the frame mount may have kind of an oblong hole for the damper.
Edit: after checking partzilla, just about every KZ known to man uses the same rear turn signal dampers, your bike & mine included. I installed K&S stems from Z1Ent & they were a direct swap. mine were longer but otherwise the same.
Last edit: 25 Jan 2019 15:18 by martin_csr.
- 650Dude
- Banned
25 Jan 2019 15:43martin_csr wrote: By 650Dude: yeah, I was about to say they wont fit. The triangular shaped part doesnt fit in the mounting hole on the bike....
Thanks for this. I will check the stems, but it sounds like you may be right that they all utilize the same configuration.
- slmjim+Z1BEBE
30 Jan 2019 08:44 - 31 Jan 2019 05:16z1kzonly wrote: The 650 looks different than Z1/KZ900/1000. At the mount. Plus they are spline cut at the blinker.
Most wires connectors slip through with the male connector
Buy another 650 set from ebay and just do it! Sure they are cheap enough.
Cut em up!!! Beat em up!!
Yes shorten them! I have to hack everything up for my 1 off build !
You can borrow my Harley tools!
Chuckle...
Was reading all the 650Dude drama we missed & saw this. Reminded of a saying from... ???
"DON'T FORCE IT!!. Use a heavier hammer."
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com/index.html/
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 31 Jan 2019 05:16 by slmjim+Z1BEBE.
31 Jan 2019 05:08 - 01 Feb 2019 05:26
Last edit: 01 Feb 2019 05:26 by martin_csr.
