1978 KZ650 starter motor gasket - pictures included
- LexPaul
12 Jan 2019 10:27 - 12 Jan 2019 10:29
Members, my starter problem manifested itself by kicking over and then screeching. Push the button again and it rolls over then screeches. When the screeching begins, the starter stops turning over. I thought it might be a stripped tooth on the planet pinions #19 on the drawing and so I removed the unit for inspection but everything does seem to look okay. The output shaft #20 seems to spin fine now but it did not a first because of some debris in teeth. I’m not sure if the debris is something that fell in as i disassembled the unit or not, but it is clear now. See below questions,
Do you master mechanics suggest I should look elsewhere while I have this unit apart?
The gasket #16 is shot and needs replacing. The picture shows what is left of the gasket. I cannot find a part # online. Can anyone send me this part # or cut me a gasket for a fee? I would cut my own but in 7 years or peddling with these old bikes, I’ve never had to buy the gasket supplies and they’d just go to waste in the storage box. I can provide measurements.
Thanks ahead for any help offered. LexPaul
1975 Yamaha RD125A
1978 Yamaha RD400E
1978 Kawasaki KZ650B2
1978 Yamaha RD400E
Last edit: 12 Jan 2019 10:29 by LexPaul.
Re: 1978 KZ650 starter motor gasket - pictures included
12 Jan 2019 11:07 - 12 Jan 2019 11:08
The problem you describe is indicative of a starter clutch problem rather than a bad starter. The only thing I question is when you state "the starter stops turning over." It seems much more likely that the starter still turns over, but the starter clutch is slipping so the engine does not turn over. If the starter stopped turning I don't believe you would hear the screeching sound.
The starter clutch has several components. The starter clutch gear tends to wear unevenly (see 1st image below) and this can cause the problem you describe. Now take a look at the second image below. To rebuild the starter clutch one should at least replace the 3 springs (10) and the starter clutch gear (14). When the unit is disassembled one also needs to check to see if the starter clutch (9), the 3 pins (11), or the 3 rollers (12) are damaged or worn. If so they should be replaced. Ed
Last edit: 12 Jan 2019 11:08 by 650ed.
- LexPaul
12 Jan 2019 11:26
I would say that you are spot on with, the starter still turns over, but the starter clutch is slipping so the engine does not turn over. I will break this down further and see what is up. Thank you very much.
Gasket part# anyone?
1975 Yamaha RD125A
1978 Yamaha RD400E
1978 Yamaha RD400E
12 Jan 2019 11:32
The following user(s) said Thank You: BCScott
