The little wiring nest to the left of the reg rec is about all there is on the bike. The battery area only has two big battery cables But the battery is not in the bike for winter so the battery cable is floating free in the photo.
The right side only has the igniter.
I put the turn signal control unit under the tank in the frame pocket between the two neck reinforcement plates.
I welded nuts onto the sub-bracket that bolts to the side of the battery box, then bolt the reg/rec to that. I had to bend a tab or two out of the way, but the reg/rec fits nicely.
Last edit: 11 Feb 2019 16:08 by loudhvx.
