1981 KZ750 LTD - need key help
- Oldad67
26 Dec 2018 16:01
I have a 1981 KZ750 LTD that was bought with this switch in the picture on it. I dont have a key, and im trying to get a key for the seat lock. It needs a new battery to see if it will run.
I dont want to buy a switch until i know the bike will run. Can anyone get me a key from the numbers on this switch? Or tell me who to contact about getting a key.
Re: 1981 KZ750 LTD - need key help
27 Dec 2018 07:52 - 28 Dec 2018 06:15
A good locksmith should be able to make a key from the code. Also, there are keys available on eebbaayy.
Key blank that may work >>> Ilco KA14 X103. It has the same shape as the Kaw keys in the pic.
It's what I'm currently using. your ignition switch should be the same as mine.
Last edit: 28 Dec 2018 06:15 by martin_csr.
27 Dec 2018 07:57
I'd hot wire it to see if it will run.
27 Dec 2018 08:04
He said he needs a new battery to see if it will run, so a key is still needed.
27 Dec 2018 08:14
That switch looks trashed.
27 Dec 2018 12:10 - 27 Dec 2018 12:11
I'd guess he's planning on hot wiring it to start it or fab up some sort of simple start switch. or perhaps the old switch is still functional by turning it with a screwdriver or something. ???
Last edit: 27 Dec 2018 12:11 by martin_csr.
27 Dec 2018 18:49
For test starting purposes, can use any automotive type 12 volt battery to temporarily provide power to the coil primaries .
Important to disconnect battery power when not engaging the electric starter or not actively kick starting or when the engine isn't running. In other words, leave battery power connected only when engaging the electric starter or actively kick starting or when the engine is running.
28 Dec 2018 06:14
That's what I did to see if my 650 would start. old battery removed since it was old & shot. jumper cables connected to the mc battery leads & to the car battery (car engine off, car keys in pocket). start motorcycle. just make for darn sure you don't reverse the polarity. I would guess this would be one of the easier ways to mess that up.
- Oldad67
19 Jan 2019 14:39
I had a key made for switch. ilco kw15bp. Won’t go in seat lock. UNDERSTAND i am trying to unlock seat to get to battery to replace and attempt to crank bike. I will deal with ignition switch later. THANKS TO EVERYONE.
20 Jan 2019 05:47
It won't physically go into the seat lock or it just won't unlock it?
