KZ 650 Timing
- jadkins91
KZ 650 Timing
21 Nov 2018 10:03 - 21 Nov 2018 10:03
When setting timing with my newly installed Dyna ignition which advance timing mark should i line up with the mark on the engine casing?
1978 Kz650 B
1978 Kz1000
1981 kz750
1978 Kz1000
1981 kz750
Last edit: 21 Nov 2018 10:03 by jadkins91.
Re: KZ 650 Timing
21 Nov 2018 11:52
On my Z1 and KZ900, I use the F mark, same as with the stock points ignition.
There are several different styles of F marks on the various advancers. The F mark is sometimes easy to identify, and sometimes less easy to identify. Let us know if you're uncertain exactly which mark is the F mark, or would like to see some examples of the different style marks.
- loudhvx
Re: KZ 650 Timing
21 Nov 2018 14:00
As Patton said, you would use the factory's F mark for manually timing the Dyna S.
The photo you posted is for an electronic ignition on a Kz550. A points-driven 650 would probably look different. The electronic ignition advancers don't usually have an F mark for cylinders 2 and 3. The points version did.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Re: KZ 650 Timing
21 Nov 2018 20:57
With the Dyna S you are supposed to set the timing at full advance using a timing light. You can set it at the F mark statically and it will be close but you still have to check it at full advance to be sure it's right.
- zukdave
Re: KZ 650 Timing
22 Nov 2018 09:23 - 22 Nov 2018 09:32
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 22 Nov 2018 09:32 by zukdave.
