Voltage drop at coils.
- jadkins91
31 Oct 2018 10:04 #793166
by jadkins91
1978 Kz650 B
1978 Kz1000
1981 kz750
Replied by jadkins91 on topic Voltage drop at coils.
I don't believe that there are any wires in the handlebars. Could this be a possible grounding issue?
1978 Kz650 B
1978 Kz1000
1981 kz750
- loudhvx
- Thank you received: 1616
31 Oct 2018 10:11 #793168
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Voltage drop at coils.
If the fuse blows instantly, the likelihood is that a 12v wire is coming into contact with a ground somewhere.
If the fuse is glowing hot for a while before blowing, then it could be an over-draw from a load, but that is less likely.
If the fuse is actually just melting from heat rather than current, it could be dirty fuse holders. The resistance I spoke of earlier creates a potential hot spot (evidenced by discolored wires etc). If the hot spot gets hot enough, it can melt a fuse. This has been seen many times on Kzrider.
1981 KZ550 D1 gpz.
Other links.
- jadkins91
05 Nov 2018 05:13 #793387
by jadkins91
1978 Kz650 B
1978 Kz1000
1981 kz750
Over the weekend i got the bike started again. Bad news is the bike idles really sluggish and once i give it some gas it backfires and bogs out. Any idea on what could be causing this?
1978 Kz650 B
1978 Kz1000
1981 kz750
- Thank you received: 2098
05 Nov 2018 05:16 #793388
by Patton
Possible causes would include too tight intake valve(s).
Replied by Patton on topic Voltage drop at coils.
jadkins91 wrote: Over the weekend i got the bike started again. Bad news is the bike idles really sluggish and once i give it some gas it backfires and bogs out. Any idea on what could be causing this?
