Regulator Rectifier upgrade
- Robb2018
- 76 KZ900 73 Z1 A
30 Sep 2018 08:36 - 30 Sep 2018 08:44
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationHi all...
My 76 KZ900 isn't charging. During the troubleshooting process, I read about the problem with the rectifier catching fire and how it's strongly recommended to upgrade from the OEM separate regulator and rectifier to a new combination regulator/rectifier. Saw these two on Ebay. Can anyone suggest one over the other or some other unit that's better. I saw the one from Redline Cycle but it's over twice as much as either of these. Also, what are potential challenges in using a universal regulator rectifier? I'd appreciate anyone's thoughts on the subject.
Oh... before I go, a little background. I'm pretty sure the bike was charging about a month ago before I put the project on hold for a while. Haven't ridden it or done anything to it, now it's not. Under those circumstances this seems like a bad connection somewhere, but I figured since the stock rectifier is a potential problem with these bikes I should start by replacing that.
KZ900; Z1
Last edit: 30 Sep 2018 08:44 by Robb2018.
- loudhvx
Re: Regulator Rectifier upgrade
30 Sep 2018 09:19
With a stock alternator, I would try a used Ninja regulator/rectifier. They are dirt cheap and plentiful. Don't use anything over 20 years old, though.
If you have the money to spend, you could also try the Shindengen series-pass regulator. But make sure not to get a counterfeit version.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: Robb2018
- ThatGPzGuy
30 Sep 2018 09:51
I just replaced my XS650 regulator and rectifier with one of these units for less than that one on eBay. They also offer a one year warranty and support.
ElectroSport
ElectroSport
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Robb2018
- 76 KZ900 73 Z1 A
30 Sep 2018 10:01 - 30 Sep 2018 10:01
Good info thanks to you both. How about rewiring the connector to fit the panel? Can the 3 power lines go in an any power hole or is there an order? Also, does anyone sell the blue green white brown replacement plugs? Been looking but haven't found any available.
KZ900; Z1
Last edit: 30 Sep 2018 10:01 by Robb2018.
- Robb2018
- 76 KZ900 73 Z1 A
30 Sep 2018 10:10
No eBay APP ID and/or Cert ID defined in Kunena configurationWould this work?
KZ900; Z1
- ThatGPzGuy
30 Sep 2018 10:44Not sure but the reg/rec I bought came with the correct plugs. A simple swap really...Robb2018 wrote: Good info thanks to you both. How about rewiring the connector to fit the panel? Can the 3 power lines go in an any power hole or is there an order? Also, does anyone sell the blue green white brown replacement plugs? Been looking but haven't found any available.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
30 Sep 2018 11:01 - 30 Sep 2018 11:01
A SERIES R/R like the Shinden SH775 is vastly superior to the standard shunt type R/R that most people use. For one thing they help protect your stator from return current overheat damage and secondly, they are made by a well respected Japanese company and are extremely robust. I've posted dozens of times about the superiority of the SH775 but for some reason most people around KZR ignore this advise. If you need more conceiving try google searching on SH775 and read for yourself. They are no more expensive than a cheap Chinese shunt R/R too. It's a nobrainer.
Last edit: 30 Sep 2018 11:01 by Nessism.
- 9er rider
- Keep a cool tool
30 Sep 2018 12:11 - 30 Sep 2018 12:39
Ive upgraded to a sh 775 on my 78 1000b and as soon as I quit riding for the year, Il upgrade my kz900 as the same plus an upgrade to blade fuses to both. They're Both simple installations. Currently lowering my complete back yard 6" to grade by hand, adding patio, sod and gardening. Good exercise but running out of money doesn't count as exercise unfortunately.
Last edit: 30 Sep 2018 12:39 by 9er rider.
- loudhvx
30 Sep 2018 13:06
The series pass regulator is only vastly superior if the alternator is vastly too powerful for the normal bike load. The Kz's alternators are pretty well-matched to the load of the bike so the shunt type works well, and works well for 40 years. If you get a really powerful alternator/stator, and don't have extra lights etc to use the extra power, then you'd be better off with the series-pass. But for a well-matched load, as in a stock bike, the series pass is an improvement, but I wouldn't say it's "vastly superior" .
You can get recent factory reg/rec's used for $10. That's pretty hard to beat as a value.
I believe that factory ZX12R reg/rec would work if it is a 6-wire reg/rec. That is Black, Brown, Red, and three Yellow wires. But I haven't actually tried it. I've only actually tried ones from a Ninja 500/250 or maybe Ninja 650 from the mid 2000's.
1981 KZ550 D1 gpz.
Other links.
Other links.
30 Sep 2018 14:11Robb2018 wrote: Hi all...
............. I read about the problem with the rectifier catching fire ..........
:laugh: Really? Where did you read that the rectifier would catch fire? I've owned my KZ650-C1 for more than 41 years (bought it new). It has the stock rectifier and stock separate voltage regulator, and I've never had any signs that the rectifier got hot much less caught on fire. Ed
30 Sep 2018 15:22
This video may assist you to determine why you aren't charging your battery.
- perrykz1000
- Have a safe day !!
30 Sep 2018 17:49Please Log in or Create an account to join the conversation.
