Kawasaki OEM Electronic Ignition - Adjusting Timing
  • Clive1978
  • Clive1978's Avatar Topic Author
25 Sep 2018 08:34
#791402
This may sound thick , but how do you adjust the timing on the above , the timing plate does not adjust ?
KS650SR D1A
  • loudhvx
  • loudhvx's Avatar
Re: Kawasaki OEM Electronic Ignition - Adjusting Timing
25 Sep 2018 09:01
#791403
There is no adjustment. Your photo shows it to be pretty close.
How far off is it? If only a bit, then you can elongate the mounting holes with a file.
  • DFIGPZ
  • DFIGPZ's Avatar
28 Sep 2018 19:05
#791566
slot the mounting holes.
1984 750 Turbo
The following user(s) said Thank You: Clive1978
