- Thank you received: 21
Speedometer app
- Togoster
24 Aug 2018 08:42 - 24 Aug 2018 08:43 #789682
by Togoster
Get your motor running!
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
Speedometer app was created by Togoster
Noodling around with a few speedometer apps and they are pretty neat. These are gps and more accurate than my Speedo since I changed the gearing slightly. It records data from the trip, likely funnels all that info to your insurance company, the police, the fbi, and the Russians but I don't care. Also, will test a tach app that gauges rpm from sound.
Downside seems to be when viewed in full sun. At night I figure it works quite well.
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
Last edit: 24 Aug 2018 08:43 by Togoster.
- JMKZHI
- Thank you received: 48
25 Aug 2018 07:12 #789778
by JMKZHI
Replied by JMKZHI on topic Speedometer app
How does changing the gearing affect the speedometer?
- Thank you received: 2829
25 Aug 2018 08:51 - 25 Aug 2018 08:52 #789785
by 650ed
It would have no affect, at least not on my KZ. The speedometer on my bike is operated by a cable attached to a gizmo on the front axle. So any changes made to the sprockets, tranny, or anything else that relates to the rear wheel would not affect the speedo. If one was to install a front wheel with a larger or small diameter than the stock one the speedo would be affected. Ed
Replied by 650ed on topic Speedometer app
JMKZHI wrote: How does changing the gearing affect the speedometer?
Last edit: 25 Aug 2018 08:52 by 650ed.
