Is this what a fried connection looks like? What would cause this?
- JoeyCrush
11 Aug 2018 19:28 - 11 Aug 2018 19:29
I'm currently working through replacing my single phase stator with a triple phase stator and replacing my regulator rectifier when I noticed the connection below. The left white/red wire is connected to the battery and the right white/red wire is connected to the reg/rec.
It appears to have been burned - am I correct? This might explain why the regulator rectifier was toast.
What would cause this? Should I be looking to replace something else in my electrical system?
1980 KZ550A
Chicago, IL
Chicago, IL
Last edit: 11 Aug 2018 19:29 by JoeyCrush.
Re: Is this what a fried connection looks like? What would cause this?
11 Aug 2018 20:40
Yes, that connection definitely overheated. There is a variety of possible reasons, but if the regulator was not limiting the current level that could be a cause. Ed
- slmjim+Z1BEBE
11 Aug 2018 22:27 - 11 Aug 2018 22:29
In addition to what 650ed indicated, a common problem is that female barrel connectors relax a little with age & heat, loosening grip on it's male mate.
Separate the connectors. Examine them for corrosion and carbon deposits from arcing, and clean the mating surfaces to show bright brass again. Then, before reassembly, gently squeeze the female connector so it's slightly more closed, which will tighten it's grip on the male pin.
We use NO-OX-ID electrical contact grease on all pin & blade connectors. It helps prevent corrosion, improves conductance and supplies more surface area for heat dispersion.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 11 Aug 2018 22:29 by slmjim+Z1BEBE.
- loudhvx
12 Aug 2018 07:44
Age and dirt. The connections should be cleaned and dried, and try to tighten up the fitting if you can.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
12 Aug 2018 10:25 - 12 Aug 2018 10:25
It depends upon how bad the damage is of course, but in some cases you may have to replace the terminals & sometimes the wire. That red-white power wire is kind of important.
Last edit: 12 Aug 2018 10:25 by martin_csr.
- bluej58
12 Aug 2018 15:09
I would suggest checking and cleaning your fuse connections too
78 KZ1000 A2A
13 Aug 2018 11:36
Deoxit D-5 is another good choice for cleaning and protecting electrical contacts.
- bluej58
13 Aug 2018 15:39
I used Deoxit-5 on (ALL) my connections 8 years ago after letting the bike sit for twenty years and have put over 50,000 miles on her since with zero electrical troubles related to the bikes wiring.
78 KZ1000 A2A
