Waterproof connectors
06 Aug 2018 17:39
If these really work, they could make wiring projects much easier for the ammeters among us.
chicdelta.com/products/waterproof-solder-wire-connectors
The following user(s) said Thank You: JR
Re: Waterproof connectors
06 Aug 2018 18:10 - 06 Aug 2018 18:10
A good soldering iron (skills) and some piece of shrink tube do the same job.
Last edit: 06 Aug 2018 18:10 by Scirocco.
- Togoster
06 Aug 2018 19:26
The factories don't use solder joints tho. Factory correct connectors are available but the crimping tool is like $200+ US. That's why I'm thinking mitigate at that point
Get your motor running!
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
- Togoster
06 Aug 2018 19:27
Motogadget
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
07 Aug 2018 05:44 - 07 Aug 2018 05:46By Togoste:
The factories don't use solder joints tho. Factory correct connectors are available but the crimping tool is like $200+ US. That's why I'm thinking mitigate (Motogadget) at that point
To install open barrel terminals which are the same as stock there are affordable crimpers available. I already had a Harbor Freight ratcheting crimper, but the dies were wrong, so I got the correct open barrel die set off of amazon.com. CycleTerminal.com has a crimper that costs about the same as what I ended up paying in total, about $30 or so. Z1Enterprises.com may have a crimper as well.
Last edit: 07 Aug 2018 05:46 by martin_csr.
- slmjim+Z1BEBE
07 Aug 2018 08:22They'll do for butt connectors. Very common in the recreational marine industry. The set shown has sizes unlikely to be useful on a bike.TexasKZ wrote: If these really work, they could make wiring projects much easier for the ammeters among us.
Never heard of chicdelta. Looks like a poorly-performing Chinese site. They're really vilified on fakebuuk.
m.facebook.com/pg/Chic-Delta-187306448744731/reviews/
Amazon has same/similar items cheaper, especially if bought in bulk.
www.amazon.com/Sopoby-Connectors-Electri...waterproof+connector
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
