1977 KZ1000 A1 head light
- Wilcocar
01 Aug 2018 18:01
I have a 1977 KZ1000 A1 that i am restoring and it has the original 7 inch sealed beam 35W halogen bulb in it. Wondering what my head light options are any recommendations or info would be helpful thanks.
1977 KZ1000 A1
The following user(s) said Thank You: BCScott
Re: 1977 KZ1000 A1 head light
01 Aug 2018 18:13 - 01 Aug 2018 18:16
If your 1977 Kawasaki had a halogen bulb in it the bulb was not original. After trying numerous brands and wattages I use a Wagner halogen in my 1977 KZ650. It's rated as 60w high beam / 35w low beam (see link below). Ed
www.brandsport.com/wagl-h6024.html
Last edit: 01 Aug 2018 18:16 by 650ed.
The following user(s) said Thank You: Wilcocar
01 Aug 2018 18:14
Moved this topic to electrical for you being new to us.
In the future please take a extra moment to put topics in the right section .
Our default section is engines
01 Aug 2018 18:14 - 01 Aug 2018 18:20
I upgrade my head light with an Highsider 3 LED head light insert.
Plug and Play, best you can get for "less" money
www.kzrider.com/forum/11-projects/605133...mode?start=40#782124
Last edit: 01 Aug 2018 18:20 by Scirocco.
- JR
01 Aug 2018 19:29 - 01 Aug 2018 19:31650ed wrote: If your 1977 Kawasaki had a halogen bulb in it the bulb was not original. After trying numerous brands and wattages I use a Wagner halogen in my 1977 KZ650. It's rated as 60w high beam / 35w low beam (see link below). Ed
I also bought a Wagner H6024 a few months back (on Ed's recommendation). Brighter than what I had, great price and pretty much plug and play for my bike.
I'm sure Scirocco's LED is much brighter but I dont ride at night any more. Just looking for something to shine a few extra lumens at oncoming traffic and aid day time visibility
Last edit: 01 Aug 2018 19:31 by JR.
01 Aug 2018 20:32
The original bulb in NA at least up until 1976 was a sealed beam Stanley with the marking 001-1014 on it. European bikes used a Koito with removable bulb.
01 Aug 2018 21:26
- slmjim+Z1BEBE
02 Aug 2018 07:48
Nothing at all wrong with a good halogen headlight. Does it say "DOT" or " MOTORCYCLE" on the lens?
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com/index.html/
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
02 Aug 2018 09:28
The Wagner H6024 has "DOT" molded into the glass lens and also printed on the back of the lamp. It is not motorcycle specific, but I have found that it works very well - much better than the stock incandescent lamp. I used Sylvania halogen lamps a while back, but found they failed in about 1 year so that's not very good. The Wagner lamps last well over 10 years in my KZ650. Way back when I used a Marchal halogen motorcycle lamp. It worked well, but the removable bulb burned out fairly quickly. I replaced the original bulb with a 100w one - BIG mistake! It was extremely bright which I loved, but over time it cooked the reflective surface inside the Marchal lens and cooked the bike's electrical connector. Lesson learned. Ed
- Wilcocar
03 Aug 2018 10:39
Thank you to everyone! I have found what I needed, ended up getting the Wagner H6024 55w low beam should be plenty for my usage. Also I accidentally put halogen it was the original 50/35w Stanley.
1977 KZ1000 A1
- BCScott
09 Sep 2018 20:12
Thanks for starting this thread. I was just starting to look for a bit of an upgrade to the oem light on my A1. I don't ride at night much, but we have lots of skittish elk on my road and no street lighting, so when I do, it'll be nice to have a bit more light.
Back in the saddle and loving it! KZ1000A1
- BCScott
18 Sep 2018 21:34
I couldn't find a Wagner locally. but got the Phillips halogen equivalent last week (for $11). The ride home from volunteer fire practice tonight was excellent. A huge improvement over the Stanley incandescent.
