Kz1100 headlight out - stuttering idle
- chrisM
25 Jul 2018 11:45
Hi everyone,
Getting ready to drive a 1982 Kz1100A from SF to Boston and keep having a reoccurring problem:
Headlight goes out. Blinkers stop working temporarily and at the same time the engine is doing some strange things. I am fairly new to motorcycles and have done some "work" on the bike myself, but it's mostly trial and error.
I just cleaned the carburetors with help from a mechanic and was hoping that would make the bike run smoother - but it sounds the same:
When it idles, sometimes its very high (almost 3k) and sometimes it sounds like it's a bout to die.
When I drive on the highway, sometimes the RPM will just drop to 0. Zero! and then randomly, it will go back up and the bike will lurch forward.
Any help would be greatly appreciated!! Thank you!!
Chris
Chris
- KzJim
Re: Kz1100 headlight out - stuttering idle
25 Jul 2018 14:03
Sounds like you still have carb issues. High idle is usually a vacuum leak somewhere, not wanting to idle is primary circuit issues..
As for the headlight, something could be shorting out in the headlight housing. Start looking for anyplace the PO has hacked into the harness that could possibly cause issues. Sorry there's no simple answer as to whats causing the issues, you're going to have to start troubleshooting. Get yourself a test light and a volt meter and start looking.
I'd seriously get the issues straightened out prior to even thinking about a cross country trip..
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
The following user(s) said Thank You: chrisM
- daveo
30 Jul 2018 00:22
Take a close look in the fuse box. Check for a loose or dirty fuse connection, and examine each one. May want to replace a couple fuses, depending on condition.
1982 KZ1100-A2/1170 sleeper 😀
