Stator, «thinking failure?»
  • gordone
  • gordone's Avatar Topic Author
20 Jul 2018 14:05 - 20 Jul 2018 14:06
#787289
My stator is orginal and from 1981, test looks good and charge voltage is good.
My concern can the stator stop working anytime? Should I replace it?
I have installed serial regulator so these should extend the life....
Project:
Last edit: 20 Jul 2018 14:06 by gordone.
  • Nessism
  • Nessism's Avatar
Re: Stator, «thinking failure?»
21 Jul 2018 04:26 - 21 Jul 2018 04:27
#787322
Sorry, can't remember from your other thread but what is your charge voltage at 5000 rpm?  And what numbers are printed on the top of the R/R?  Does it say SH775 or something to this effect?  If it doesn't have this printing on top it's NOT a SERIES type R/R.
Last edit: 21 Jul 2018 04:27 by Nessism.
  • loudhvx
  • loudhvx's Avatar
21 Jul 2018 13:05 - 21 Jul 2018 13:07
#787342
From what I remember it was charging too high before. So that would indicate the stator is fine.
Yes, the stator can stop working anytime.  No, you shouldn't replace it.  It wouldn't hurt to have a good spare on a shelf if you can find one cheap.
Last edit: 21 Jul 2018 13:07 by loudhvx.
  • gordone
21 Jul 2018 14:44 - 21 Jul 2018 14:45
#787350
I don’t wanted to mix the two topics :) charge voltage case is not closed yet :)
It’s marked SH775 something.
I found a test on google how to check wheter is a serial or mosfet.
I wanted to get some more info about the stator. So from what you saying I shall just use what I have until it stop working, replace it with a new one is not a garantue for not stop working?
Project:
Last edit: 21 Jul 2018 14:45 by gordone.
  • Nessism
  • Nessism's Avatar
21 Jul 2018 15:04
#787352
gordone wrote: So from what you saying I shall just use what I have until it stop working, replace it with a new one is not a garantue for not stop working?
Correct.  Use what you have until it fails.
The following user(s) said Thank You: gordone, Scirocco
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
21 Jul 2018 17:09
#787360
the stator on my Z1 is 43 years old and working fine. I will keep it until it fails.
Blue 1975 Z1B
Red 2009 Concours 14
  • gordone
22 Jul 2018 02:49
#787379
Z1Driver wrote: the stator on my Z1 is 43 years old and working fine. I will keep it until it fails.
Have you done some maintenance? I have seen some talking about having fresh engine oil on it?
Project:
  • hardrockminer
  • hardrockminer's Avatar
22 Jul 2018 05:09
#787381
The alternator operates on a principle of physics that if you move a wire in a magnetic field (or the reverse) you will generate a current flow in the wire.  The magnetic field is provided by the rotating magnets on the end of your crank.  The stator sits inside it's cover while the magnets rotate without touching anything and a current is generated in the stator wires.  This is what eventually charges the battery.  So no parts touch each other and there is nothing to wear out.  The stator could possibly develop a short or a broken wire, but it's rare and not predictable.  You might improve the very small odds of a failure by replacing your stator but you will pay for a new one and perhaps needlessly.  As Z1Driver said, my Z1B's are 43 years old and still have the same magnets and stator coils.  They work just fine and I have no plans to replace.
