Help with intermittent spark - 78 KZ400
- Stockton350
19 Jul 2018 19:30 - 19 Jul 2018 19:30
When I check for spark (spark plug in the boot, plug against the engine case) I sometimes get spark and sometimes don't. Battery is full, boots and plugs are new, checked point gaps, new coil checks within specs. I also made sure the ground battery terminal had a good connection to the frame. Any suggestions?
1975 CB125 |
tinyurl.com/jds9l7q
1976 CB350
1978 KZ200 | tinyurl.com/j3odxo8
1976 CB350
Last edit: 19 Jul 2018 19:30 by Stockton350.
- One1
- KZ 750 FOUR
Re: Help with intermittent spark - 78 KZ400
19 Jul 2018 20:07
Run a separate ground to the engine block. As the mounts age and become rusted from the inside out it's possible to loose contact between the frame and block.
Vulcan 750, KZ750, KLX 125, and many more......
19 Jul 2018 20:21Stockton350 wrote: ................ I also made sure the ground battery terminal had a good connection to the frame......
Frame? I'm not familiar with the KZ400 setup, but the KZ650 ground cable attaches to the engine. Ed
- One1
- KZ 750 FOUR
19 Jul 2018 22:07 - 19 Jul 2018 22:08650ed wrote:Stockton350 wrote: ................ I also made sure the ground battery terminal had a good connection to the frame......
400/440 attaches to the frame right beside the battery. cable is 4 inches long.
Last edit: 19 Jul 2018 22:08 by One1.
- VTEC
21 Jul 2018 16:10
Check the voltage drop on the power feed to the coils. There's an accumulation of lost voltage there including the ignition switch, kill switch, and all the old connectors in between.
Next time you have no spark check the voltage at the coils compared to the battery. The difference is voltage drop. You may even have nothing due to an intermittent open in the circuit.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
- Fischer779
- My bike runs on the tears of bald eagles
21 Jul 2018 19:21
Did you check the Plug Gap? Spark plug gap may be different on new plugs. Might want to check that and remove a variable.
YZ400f "dual sport"
KZ400D
95' Corvette
KZ400D
95' Corvette
