I need to replace my fuse block
- Nightdriver
08 Jul 2018 07:33
The front side of the 30 amp main is overheating and melting the strip inside.
I've gone through the harness as best I can and can't find any shorts.
Should I just get one from ebay?
Or would a newer blade type one be better ? If they are where would I find one that fits?
'82 1100 Specter
- DoctoRot
Re: I need to replace my fuse block
08 Jul 2018 10:49
I have used a 4 circuit, blade type I fuse box and use the extra circuit spot for the “coil relay mod”
double win
double win
08 Jul 2018 11:18
I installed a 30 amp blade type and use the stock for lighting and such. It opened a slot for more low power circuits.
