- Thank you received: 1
Help with a no spark 1978 KZ400
- Stockton350
07 Jul 2018 11:21 #786572
by Stockton350
1975 CB125 | tinyurl.com/jds9l7q
1976 CB350
1978 KZ200 | tinyurl.com/j3odxo8
Help with a no spark 1978 KZ400 was created by Stockton350
Hi - I've got a KZ400 project bike that I just pulled out of the barn. I've got 12v going into the coils. I checked the points and I get 12v/10v when they open/close. Is it supposed to drop to 0v?
If the above it okay, what's the procedure for checking the coils themselves. (It's a new unit that I got last fall, but worth a check I'm thinking.)?
Thanks in advance.
Thanks in advance.
1976 CB350
- loudhvx
- Thank you received: 1616
08 Jul 2018 16:36 #786640
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Help with a no spark 1978 KZ400
There are two wires on the coil. One should stay near 12v.
The other wire will switch between 12v and 0v as the points open and close.
Close should measure near 0v.
Open should measure near 12v.
1981 KZ550 D1 gpz.
Other links.
