Kz900 ignition timing with dyna s ignition
  • zak900
  • zak900's Avatar Topic Author
01 Jul 2018 13:45
#786236
Does the timing need to be any different with dyna s electronic ignition compared to standard points ignition on my 1976 KZ900 A4?
Let the good times keep rollin'
1976 KZ900 A4
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Kz900 ignition timing with dyna s ignition
01 Jul 2018 13:58
#786237
You set it at full advance then adjust the idle down.
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
  • zed1015
  • zed1015's Avatar
01 Jul 2018 14:06 - 01 Jul 2018 14:07
#786238
Ignition timing stays the same.
40 degrees full advance.
Last edit: 01 Jul 2018 14:07 by zed1015.
  • zak900
01 Jul 2018 14:19
#786240
What is that in mm btdc please?
1976 KZ900 A4
  • zed1015
  • zed1015's Avatar
01 Jul 2018 14:26
#786241
Haven't a clue.
You just use the timing marks on the advancer and the ignition case.
If you need to comfirm the marks are 100% accurate use a degree disc but for road motors the factory marks are good enough and a degree either way won't make a difference.
