No power
  • Nicknhra
  • Nicknhra's Avatar Topic Author
No power
20 Jun 2018 13:02
#785522
Earlier today I went for a ride, all of a sudden motor died so I came to a stop put it in neutral and my notification light was not on. So I checked my fuses the Ignition fuse was Blown and the headlight was working with key on, I tried swapping my headlight fuse to get home that didn't work. So I got it home noticed the headlight turn signals all worked but no neutral light was working wouldn't crank over. Neg cable was loose I re tightened the cable still nothing now Ive lost all power all together. Any thoughts??
1981 Kawasaki kz1000M
  • wiredgeorge
  • wiredgeorge's Avatar
Re: No power
20 Jun 2018 15:54
#785529
Make up a signature and put your bike year and model in the same. I hesitate giving advice without knowing which bike is being asked about. Cheers!
  • Nicknhra
Re: No power
20 Jun 2018 16:02
#785532
Sorry forgot that!! 1981 Kawasaki kz1000M
  • Nicknhra
Re: No power
21 Jun 2018 16:48
#785618
So upon further investigation, I have 12.7 at battery, I have 12.7 at main 30 amp fuse but no where else key on no power on any of the fuses but the main fuse. I jumped the main fuse with the ignition/horn with a wire low and behold I got power, I think I might have a faughlty ignition switch?! Pulled clutch in bike cranked over no problem.
Jumpered main to taillight fuse, tail light works and so forth. Tried jumpering to the headlight fuse but no luck headlight did not come on, (if the switch was bad it needs to be on for the headlight to work correct?)
Thanks for your help!
  • Nicknhra
Re: No power
01 Jul 2018 14:30
#786243
Update on this, I had a lack of connection at the fuse panel under the seat. Contacts where corroded/green
Cleaned and re-installed fuses and good to go.
  • TexasKZ
  • TexasKZ's Avatar
Re: No power
02 Jul 2018 15:46
#786312
Hurray for simple solutions!
  • gordone
  • gordone's Avatar
Re: No power
17 Jul 2018 14:30
#787119
Good ferling when you find root to a problem like that :)
Project:
  • VTEC
  • VTEC's Avatar
Re: No power
18 Jul 2018 08:01
#787163
Heavy gauge white wire with one pin connection near the fuse box is the main power feed from the 30amp fuse to the ignition switch. The only other connector between the two is behind the headlight.
KZ1000-K2
ZRX1100
XR400R
