Charge Voltage
  • gordone
  • gordone's Avatar Topic Author
Re: Charge Voltage
23 Jun 2018 16:29
#785760
Thank you all.
When I measured all cabels was connected, so ai was measured in parallel.
Tomorrow will I disconnect and measure while the bike is running.
Project:
  • gordone
Re: Charge Voltage
24 Jun 2018 10:35
#785802
I disconnected the plug from the stator, adjusted the rpm to 4-5k RPM
I measured around 80v AC between all pairs on the three yellow cabels.
These test show that the stator or magnet is good or?
Project:
  • Nessism
  • Nessism's Avatar
Re: Charge Voltage
24 Jun 2018 12:34
#785815
80 VAC is pretty good, but again, that's a no-load condition, which is not a definitive test. I'd focus on making sure you have a good R/R, and hook it up without any contact resistance in the connectors/wiring feeding the system. If you need a new R/R the best type to get is the SERIES type, not a common shunt type R/R. The SH775 is one of the best available but beware of counterfeits, which have flooded the market these days.
  • loudhvx
  • loudhvx's Avatar
Re: Charge Voltage
24 Jun 2018 13:42
#785819
The manuals only specify at 4000 RPM. It's not surprising to get more at 5000 RPM.
  • gordone
Re: Charge Voltage
24 Jun 2018 14:30
#785826
loudhvx wrote: The manuals only specify at 4000 RPM. It's not surprising to get more at 5000 RPM.
But still if the numers is better on 5k the v reading should be good enougf to have higher charge voltage then I have...?
Project:
  • gordone
Re: Charge Voltage
24 Jun 2018 14:31 - 24 Jun 2018 14:36
#785827
Nessism wrote: 80 VAC is pretty good, but again, that's a no-load condition, which is not a definitive test. I'd focus on making sure you have a good R/R, and hook it up without any contact resistance in the connectors/wiring feeding the system. If you need a new R/R the best type to get is the SERIES type, not a common shunt type R/R. The SH775 is one of the best available but beware of counterfeits, which have flooded the market these days.
I will check up the cabling. Is it these one you recommend?
Project:
Last edit: 24 Jun 2018 14:36 by gordone.
  • Nessism
  • Nessism's Avatar
Re: Charge Voltage
24 Jun 2018 16:12
#785829
That is the counterfeit. It's not a SERIES type. If you don't understand the difference please use google and read about the difference between a shunt R/r and a Series R/R. The "real" SH775's have printing on the top of the unit and cost about $150 in the USA. Those cheap jobbies are cheap knockoffs. Get a used SH775 if you have to. They are very robust.
  • gordone
Re: Charge Voltage
25 Jun 2018 06:19 - 25 Jun 2018 08:45
#785862
Now have I ordered a series type, looking forward to test it :)
Will take some weeks :) will come back with update when its installed :)
Project:
Last edit: 25 Jun 2018 08:45 by gordone.
  • loudhvx
  • loudhvx's Avatar
Re: Charge Voltage
25 Jun 2018 14:31 - 25 Jun 2018 14:34
#785884
Yes, if you are getting 80 VAC at 5000 RPM I would assume it probably passes 55 VAC at 4000 RPM. As Ed said, an open load test can only confirm a bad stator, but it doesn't necessarily confirm a good stator. It's like you want to test a bucket to hold water. So you put a few drops in it. If it won't hold a few drops of water, then the bucket is bad for sure. But if it does hold a few drops of water, that doesn't mean the bucket is necessarily good.
But as far as whether or not your stator output is considered above par or below par, according to Kawasaki, the only test they give is specified at 4000 RPM. It is not valid to score a 5000 RPM result against a 4000 RPM specification. Since it passes very high at 5000 RPM, I would expect it to pass the 4000 RPM test.
The next step, as you are doing, is to get a new reg/rec.
Last edit: 25 Jun 2018 14:34 by loudhvx.
The following user(s) said Thank You: Nessism, gordone
  • gordone
Re: Charge Voltage
28 Jun 2018 12:26 - 28 Jun 2018 12:56
#786046
Today have I hocked up the new regulator, I was cutting of existing cables and reconnected it.
When I started up the bike I got 13.30v or something over the battery, and then I measured on the output from the regulator (in parallel, everything was connected)
and then I got approx. 14.30v...
So I understand these correct have I around 1v drop somewhere, is these common on old bike? The wiring net is also old...
I was thinking rewiring so the positive and negative goes direly to the battery, atlest the positive and negative to frame.
When will I also get 14.30v on the battery.... and case is closed ? or must I figure out why ?
Must I install a fuse on the positive cable? What size?
Project:
Last edit: 28 Jun 2018 12:56 by gordone.
  • loudhvx
  • loudhvx's Avatar
Re: Charge Voltage
28 Jun 2018 14:02 - 28 Jun 2018 14:04
#786065
You don't need any additional fuses over the stock fuses.
The output of the regulator has a pretty short and direct path to the battery, possibly through the main lug connector on the starter solenoid. You should not measure a significant voltage drop on that path.
When you measure, what are you connecting the black meter lead to? It should be on the battery's negative terminal for all measurements (regarding the charging system). You should measure the voltage at the output of the reg/rec and also measure the voltage on the ground lead of the reg/rec. It's possible you have a weak ground.
Last edit: 28 Jun 2018 14:04 by loudhvx.
  • gordone
Re: Charge Voltage
28 Jun 2018 14:23
#786068
loudhvx wrote: You don't need any additional fuses over the stock fuses.
I measured direcly on the battery positive and negative. And I measured positive and negative out from the regulator.
I can search for the bad connection, but want I was wondering about is it any problem connect the reg. Direct to the battery and what fuse should I use on the positive cable?
I just want to have a plan B don’t nessarry quick to find the bad cable, and I want to rebuild the whole eletrical system another time.
Project:
