1977 KZ750 twin electrical issues
- Ramchargerjay
26 May 2018 15:57
I’ve got a 1977 KZ750 twin. It will start with the kickstarter, it will sometimes start with the starter, but sometimes won’t. When I turn the key one the running lights come on dimly and flicker while the starter is rolling over, even with all lights turned off. Sometimes after it starts it will just shut off. Any ideas? Thanks for the help
Re: 1977 KZ750 twin electrical issues
26 May 2018 16:13
Your battery have no sufficient performance/power.
Check the battery acid level is low and if necessary fill up with distilled water.
- Ramchargerjay
30 May 2018 16:41
It rolls over just fine. It’s a new, sealed battery.
30 May 2018 17:50
Could be a loose or broken wire. I'd start with both ends of the battery cables, then with all the ignition wiring.
