Blinkers
  • perrykz1000
  • perrykz1000's Avatar Topic Author
  • Have a safe day !!
Re: Blinkers
15 Aug 2018 20:05 - 15 Aug 2018 20:08
#788981
new battery, always on battery tender. does the same running or not. Right at 12.6 volts , idling 13 volts , reving engine 13 to 14 volts..
Last edit: 15 Aug 2018 20:08 by perrykz1000.
  • hardrockminer
  • hardrockminer's Avatar
Re: Blinkers
16 Aug 2018 09:17
#789021
The only grounds I'm aware of are the signals (up to all four) and the main ground from the battery. There should be two or maybe three wires at this ground point. The rectifier and/or the regulator may be grounded there along with the battery.
The following user(s) said Thank You: perrykz1000
  • JR
  • JR's Avatar
Re: Blinkers
16 Aug 2018 11:44
#789030
650ed wrote: ..................................Also, the blinkers blinked slower than I thought they should. I replaced the stock flasher with a Tridon/Stant 552 2 prong unit and the problem went away. Ed
Same here
An inexpensive solution from any auto parts store
  • martin_csr
  • martin_csr's Avatar
Re: Blinkers
16 Aug 2018 13:06 - 17 Aug 2018 01:44
#789037
I would replace the turn signal flashers with an electronic unit.
Here's a couple from autozone. Made in USA.
Novita Turn Signal Flasher. Tridon® EL12. Electro-mechanical flasher.
Novita Hazard Warning Flasher. Tridon® LL552®. Made in USA.
Last edit: 17 Aug 2018 01:44 by martin_csr.
  • perrykz1000
Re: Blinkers
16 Aug 2018 18:56 - 16 Aug 2018 18:57
#789081
Tried the LL552 flasher no difference. One more question what is the diodes purpose in the wire next to the turn signal flasher?
Last edit: 16 Aug 2018 18:57 by perrykz1000.
  • perrykz1000
Re: Blinkers
16 Aug 2018 19:58 - 16 Aug 2018 19:58
#789092
What have I done now????? Put everything back together and NOW when I turn on key , motor running or not the turn signal indictators are dimly lit , turn headlight on high beam the turn signal indicators get brighter , the high beam headlight does go to high beam BUT the high beam indicator does not light up????? When blinker is on the other lights still dim with every blink. Either the bike is trying to drive me crazy or I already am?? maybe the bike is haunted. If the diode wired to the turn signal goes bad what would happen or what would that cause. I am going over ""AGAIN"" the wiring diagram........HELP.........
Last edit: 16 Aug 2018 19:58 by perrykz1000.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Blinkers
16 Aug 2018 21:07
#789096
Do you have the hazard switch, beeper and relay? I'd try disconnecting the "diode" . It might be the hazard regulator.
  • perrykz1000
Re: Blinkers
17 Aug 2018 07:51
#789123
perrykz1000 wrote: What have I done now????? Put everything back together and NOW when I turn on key , motor running or not the turn signal indictators are dimly lit , turn headlight on high beam the turn signal indicators get brighter , the high beam headlight does go to high beam BUT the high beam indicator does not light up????? When blinker is on the other lights still dim with every blink. Either the bike is trying to drive me crazy or I already am?? maybe the bike is haunted. If the diode wired to the turn signal goes bad what would happen or what would that cause. I am going over ""AGAIN"" the wiring diagram........HELP.........
Well , I found the new problem stated above.... When I put the headlight back together one of the ground wires came unplugged ,got to be more careful with the wires when putting the headlight back on.. WHEW.... Still have the dimming problem when using the blinker. SWest ,I took diode out still the same?? MAYBE , I will get this figured out sometime hopefully , before the bike gets the best of me..... Thanks for ALL the help!!!!!!
  • perrykz1000
Re: Blinkers
17 Aug 2018 07:53
#789124
SWest wrote: Do you have the hazard switch, beeper and relay? I'd try disconnecting the "diode" . It might be the hazard regulator.
Doesnt have the hazard flasher previous owner took off I guess , it did have the flasher for the hazards and the left handle bar control has been changed (no hazard control button??)
  • hardrockminer
Re: Blinkers
17 Aug 2018 10:04
#789133
I looked at the wiring diagram. The diode prevents the flasher from operating in either direction. The hazard indicator is a separate flasher and is not directly connected to the turn signal flasher.
