Blinkers
  • perrykz1000
  • perrykz1000's Avatar Topic Author
  • Have a safe day !!
Blinkers
22 May 2018 18:40
#783849
When operating the blinkers the lights are diming with each blink. As in when blinking i can see the other side blinking too. thinking this is a ground issue. Any ides> Where to start looking at where blinkers are grounded etc> been looking for grounds all i found is where batter neg goes on motor and rear blinkers are grounded? '78 kawasaki 1000 LTD
  • kz_1000a
  • kz_1000a's Avatar
Re: Blinkers
23 May 2018 00:09
#783859
Hi Perry
My 77 kz1000 suffers the same problem if I do not have a good earth between the main harness and batt -ve / ground.
You need to ensure that the black with yellow stripe wire on your main harness is well connected to ground.
On my bike, the black/yellow wire on main harness is located closely to the brown & blue rear brake switch wires which can be found under the seat near the LHS side cover.
Verify that this black/yellow wire from harness is well connected to ground.
Best of luck.
The following user(s) said Thank You: perrykz1000
  • davido
  • davido's Avatar
Re: Blinkers
23 May 2018 00:10
#783860
When was the last time you changed the fluid?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: Blinkers
23 May 2018 13:11
#783886
^ :P ^
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • perrykz1000
Re: Blinkers
23 May 2018 14:45
#783895
Yesterday:woohoo:
  • perrykz1000
Re: Blinkers
24 May 2018 06:38
#783928
Any info to where the ground wires are attached to the frame? Any under the gas tank? Found the negative on the battery attachment on the motor and the rear blinkers ground , but cant seem to find any more unless some are under gas tank? HELP on finding any more grounds attached to frame?
  • martin_csr
  • martin_csr's Avatar
Re: Blinkers
24 May 2018 08:09 - 24 May 2018 08:12
#783939
my mistake. Suggested checking for front turn signal grounds inside headlight bucket. Some models have big collars with ground wires that're fitted inside the bucket where the big headlight bolts are.
Last edit: 24 May 2018 08:12 by martin_csr.
  • perrykz1000
Re: Blinkers
24 May 2018 13:03
#783958
Found the black w/yellow stripe on the left side ,but its not plugged into anything and I cant find where to plug in. HELP..... I also found a green w/white stripe in head light bucket broke I repaired that any idea where the blue w/white stripe wire is for?
  • kz_1000a
  • kz_1000a's Avatar
Re: Blinkers
24 May 2018 16:01
#783969
These pics might help
  • perrykz1000
Re: Blinkers
15 Aug 2018 18:30 - 15 Aug 2018 20:03
#788961
I'm still looking for why other lights are dimming when I have the blinker on. Left blinker on headlight , tail light , left front parking light all dim a little each time blinker blinks? Have headlight off AGAIN checked ALL connections not just the grounds. I soldered another ground wire to all turn signal sockets too. Could it be the flasher? I put a new one in from AutoZone ? Does it have to be a certain type flasher? Could it be the blinker control itself? Could it be in the indicator panel (neutral,oil,brake,high beam,turn signal indicator) I'm at my wit's end.... HELP !!!!!!!
Last edit: 15 Aug 2018 20:03 by perrykz1000.
Re: Blinkers
15 Aug 2018 19:09
#788965
Typically if an item momentarily pulls excessive power from the battery every light will momentarily dim when it receives less power. Years ago I had the same issue you describe when my blinkers would blink. Also, the blinkers blinked slower than I thought they should. I replaced the stock flasher with a Tridon/Stant 552 2 prong unit and the problem went away. Ed
  • hardrockminer
  • hardrockminer's Avatar
Re: Blinkers
15 Aug 2018 19:45
#788974
Check your battery to see if it's fully charged. What's the voltage when the ignition is on but the bike isn't running? What is it when the bike is running?
