82' kz750n horn failure, then tachometer stops.
- rollingfolf
17 May 2018 14:08
I have an 82' spectre, the stock dual horn, finally disintegrated and I tried replacing it with single 12v horn. (
horn this one
) and upon testing it. It worked once, then the second time it blew the 10a fuse, I replaced the fuse, the horn doesn't work and I've also lost the lights for the cluster and tach. is there another fuse inline normally?
Re: 82' kz750n horn failure, then tachometer stops.
17 May 2018 15:04
Your new horn needs too much current, (Ampere), more then the 10 A fuse
let flow. You need a relay to switsh such a high current and don't try a
greater fuse!!! You can easily burn and molten your horn button.
- JMKZHI
17 May 2018 15:29
I was thinking the same thing, but the KZ750N Spectre has two 2.5A horns, so wouldn't the current draw be the same as the new 5A horn?
- rollingfolf
17 May 2018 16:31JMKZHI wrote: I was thinking the same thing, but the KZ750N Spectre has two 2.5A horns, so wouldn't the current draw be the same as the new 5A horn?
That’s what I thought... that the two could be replaced by one. - should I just run a new line with fuse from the battery to the horn button directly?
17 May 2018 17:19
The horn button activate the relay only.
The relay close the battery + to horn to ground -, (frame ) circuit.
Some relays have a blade fuse integrated.
