Aftermarket Engine/Cylinder Temperature Sensor - '81 GPz1100
  • GPZ1100_Rider
  • GPZ1100_Rider's Avatar Topic Author
13 May 2018 14:52
#783294
I've been experiencing a rich running engine for a number of seasons. I researched the Bosch EFI systems, that were similar to the Kawasaki's of the same or approximate era. There were references to a rich condition on VWs, being caused by a bad cylinder head temperauture sensor. I looked into it. The sensor appears to be the same as what is on my '81 GPz1100, so I found two places that offered the "improved", aftermarket one. Settled on one place that offered good customer service (was helpful about my Kaw, non-auto application), service and didn't gouge on the shipping and handling cost, for a little part in a small bubble envelope.
shop.914rubber.com/Cylinder-Head-Tempera...12.htm?categoryId=-1
I had to change the electrical connector that came on it to the proper male bullet connector. Installed it, fired up the bike, and I could tell just how it was running in the driveway, that I found the fix. 75 miles of riding on highways and in the city this weekend, confirmed it was the solution to the rich running problem that I was dealing with previously. Happy, happy!
  • riturbo
  • riturbo's Avatar
Re: Aftermarket Engine/Cylinder Temperature Sensor - '81 GPz1100
14 May 2018 05:36
#783323
Wow wonder if that would fit my turbo . Its been popping that code Lately and been having the opposite problem been running crappy till it warms up . Thought it might be the injectors so I sent them out to be cleaned and flochecked but still runs rough til warm .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • GPZ1100_Rider
15 May 2018 11:03
#783415
OEM sensor part number, supposedly cross-references to the OEM sensor on '84-85 GPz750 Turbo. You'll need to verify though. Good luck.
The following user(s) said Thank You: riturbo
  • riturbo
  • riturbo's Avatar
16 May 2018 07:52
#783468
Ya looks like the same part # . Thanks for posting
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
