Tick noise, no start kz 750
  • Tesk
  • Tesk's Avatar Topic Author
11 May 2018 14:08
#783219
I put the key on and push the button, but no start only a click noise. Does someone knows? Please need help
  • mopguy
  • mopguy's Avatar
Re: Tick noise, no start kz 750
11 May 2018 16:44
#783222
You need to engage the clutch first, then the starter button.
  • riturbo
  • riturbo's Avatar
12 May 2018 15:31
#783259
Is the battery charged
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
The following user(s) said Thank You: Tesk
  • urankjj
  • urankjj's Avatar
12 May 2018 15:40
#783260
Bad connection, starter. Give the starter a slight tap if you can, like for a car starter, might help . . . . . . I really hate Tics.
  • Tesk
12 May 2018 17:53
#783270
Yes its charged. I charged it again just in case
  • Tesk
12 May 2018 17:54
#783271
urankjj wrote: Bad connection, starter. Give the starter a slight tap if you can, like for a car starter, might help . . . . . . I really hate Tics.
I opened the starter and put new carbons but no help. I bought a new solenoid relay but no help, I charged the battery but no help. What else can I do
  • urankjj
  • urankjj's Avatar
12 May 2018 19:42
#783275
Earlier post said you have to pull in the clutch lever before hitting the start button. Like in a car, (standard transmission ). Push the clutch pedal in then hit the key. Is there a fuse somewhere involved ? Or try to power the starter remotely to check for a bad starter..
  • JMKZHI
  • JMKZHI's Avatar
13 May 2018 05:42 - 13 May 2018 05:54
#783279
How old is the battery and what type is it? What type of charger are you using?
Did the battery sit for a while without being used or charged?
Did you test the battery voltage after charging and load test the battery?
It should be at least 12.6 VDC, but a good battery will be higher after charging with a good motorcycle charger.
Last edit: 13 May 2018 05:54 by JMKZHI.
  • zed1015
  • zed1015's Avatar
13 May 2018 06:13
#783282
If the solenoid clicks It is being activated regardless of pulling in the clutch or not.
If it had a starter lockout switch it wouldn't click.
If your ( new solenoid ) clicks then the live lead to the started should be powered.
You need to check the starter lead is live when the starter button is pressed which will then rule out anything before the starter assuming that the battery is good and also that the engine has a good earth connection.
Despite replacing the brushes the starter can still be faulty, burnt out, miss -wired, de-magnetised, seized etc.
You need to check that the starter spins when off the bike.
If it spins with force off the bike but not when installed there may be issues with the starter clutch or idler gear (jammed) or even a locked engine.
  • Tesk
13 May 2018 22:15
#783318
zed1015 wrote: If the solenoid clicks It is being activated regardless of pulling in the clutch or not.
Pinpoint accuracy, did what you said and it worked. Just dissasembly the starter then grease the parts that needed to be grease. And new brushes, works like a f****** charm now.
