which main harness do i need?
  • kz_1000a
  • kz_1000a's Avatar Topic Author
26 Apr 2018 05:11 - 26 Apr 2018 05:14
#782395
Hello fellow enthusiasts,
I own a '77 kz1000a1 bitza. When purchased, it came with a kaw 900 that was in many pieces, but without wiring.
The kz1000 now requires main loom replacing. Loom is finally beyond repair after a few PO's :)
I am of the belief that the current main harness & handle bar contols have been donered from the kaw 900, due to the LHS (hi/lo beam, turn signal, horn - no pass tab) control block being terminated in a single 6 pin connector which fits neatly into the corresponding 6 pin connector on the current harness.
Unfortunately, the RHS control block has been soldered directly into the main harness.
From what i can determine from schematics and pics, the z1000's control blocks mainly had "flying/single lead" terminations, as opposed to a "6 pin connector"
Given the following constraints, could anyone recommend a suitable main harness (im thinking the kz900 could work)
I would like to reuse or replace the LHS control block terminated with 6 pin connnector.
I would replace the RHS control block (flat top) from a kz900? terminated with 4? or 6? pin. (could anyone confirm number of pins?)
The warning instument cluster is original z1000a1 i.e "left & right turn signal indicators" as opposed to z1 "turn signal indicator" (is the wiring
different in the 9 pin connector?)
The current ignition switch has a 6 pin connector with 6 wires. I don't mind if "park" lights are still not usable.
The reg/rec is modern 5 wire style.
I do not have hazard light controls or associated wiring.
Please refer to current hardware below
Attachment not found
Last edit: 26 Apr 2018 05:14 by kz_1000a.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: which main harness do i need?
26 Apr 2018 07:03
#782403
No eBay APP ID and/or Cert ID defined in Kunena configurationYou may be better off with this.
z1parts.net/kz1000-main-wiring-harness-77-78/
Or this
z1parts.net/kz900-a4-a5-b1-ltd-main-wiri...-and-center-harness/
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Apr 2018 07:18
#782408
Here's the clips on mine. Used a KZ900 loom for my Z1 instruments. Rats nest wiring.
The following user(s) said Thank You: kz_1000a
  • kz_1000a
27 Apr 2018 02:17
#782471
wow, that was some spaghetti junction you managed to unclusterfork there ;) Nice work.
I would prefer the ease of disconnecting one main lead (kz900) from each control block rather than having to disconnect all the discrete leads (Z1000) from each control block, so I am hoping the kz900 loom will do the job.
  • kz_1000a
27 Apr 2018 02:21 - 27 Apr 2018 02:24
#782472
i think this is the difference between the kz900 & the kz1000
kz900 control block leads
kz1000 control block leads
Last edit: 27 Apr 2018 02:24 by kz_1000a.
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Apr 2018 08:21
#782483
It's up to you.
  • kz_1000a
29 Apr 2018 01:57
#782572
Thanks Steve, for putting that video out there.
It has answered a lot of questions about the differences between kz900/1000 harnesses.
I think i actually have a earlier z1 loom because bike has only 1 * 20A fuse, and no wires coming from loom for the other (absent, in my case) 2 * 10A fuses
I'm gonna replace my loom with kz900 and also get the 3 fuse holder because at least my LHS block control will fit it correctly.
You have helped tremendously :cheer:
  • kz_1000a
14 May 2018 05:00 - 14 May 2018 05:01
#783320
Last edit: 14 May 2018 05:01 by kz_1000a.
