Where to get a new key
  • kawikz83
  • kawikz83's Avatar Topic Author
23 Apr 2018 17:10
#782253
My key broke in half on my 83 1100LTD. Before I go an pay a locksmith place a bunch of money, is there any repro keys available for a reasonable price? And how do I find the key code on the bike? Thanks!
  • 2wheeladdict
  • 2wheeladdict's Avatar
Re: Where to get a new key
23 Apr 2018 17:30
#782255
The code on my 80 kz1000 is stamped into the outside of the ignition cylinder. You need to take it out of the housing to see it. I bought my bike without a key(owner couldn't find it). I took the code to a local locksmith and he produced a key from the code. Cost me 30$
80 KZ1000 LTD
81 Yamaha XJ650 maxim
84 CR60r
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
23 Apr 2018 18:36
#782259
This thread has a lot of good info.
www.kzrider.com/forum/4-electrical/41487...y-by-the-code-number
I've had a bunch of kz keys made from codes. All the locksmiths seem to have the data needed, although the price varies a lot. I've paid between $12 and $50. Call around I guess.
All the lock cylinders on the bike should have the code stamped into them. Try the seat lock first. It's much easier to get at. The OE keys also typically have the code stamped on them.
My dad's '74 Z1
'00 ZRX1100
  • 1slammedkz650
  • 1slammedkz650's Avatar
23 Apr 2018 20:34
#782265
There is a guy on ebay who cuts older kawasaki keys..
As the poster's above have stated the code is usually on the key itself or cylinder
He has the key blanks so you send him the code he cuts the key and mails it to you
Hope this helps
  • davido
  • davido's Avatar
24 Apr 2018 09:04
#782286
I took the whole barrel to a lock shop and they made a key to fit. T'wasnt very expensive.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • kz650guy
  • kz650guy's Avatar
25 Apr 2018 23:56
#782390
I've had some luck getting original key from ebay with the same lock code but I've also bought some from seller on ebay that just cuts new keys from your code around 20 should be average price for new or used key
  • davido
  • davido's Avatar
26 Apr 2018 04:14
#782393
No eBay APP ID and/or Cert ID defined in Kunena configurationAha!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • JMKZHI
  • JMKZHI's Avatar
26 Apr 2018 07:59 - 26 Apr 2018 08:01
#782414
No eBay APP ID and/or Cert ID defined in Kunena configurationA hardware store might be able cut a key for you, but they may need a good key to copy off of as they may not be able to cut one from a code.
ILCO probably has a blank that's a good match for your Kawasaki key, whatever type or shape it is. An ILCO KA14 X103 is almost an exact match for my 1981 KZ650 key. I did not see it in their current motorcycle catalog, but there are blanks listed on EB.
ILCO downloads - click Motorcycle key blanks
ILCO KA14 X103
Last edit: 26 Apr 2018 08:01 by JMKZHI.
  • HarryDamian
  • HarryDamian's Avatar
06 Feb 2020 05:19 - 06 Feb 2020 09:59
#818693
Locksmiths can be cheaper than going to a hardware store for getting a new key.
Last edit: 06 Feb 2020 09:59 by KZQ.
