GPZ750
- thatguyguy
GPZ750
09 Mar 2018 10:15
I have a GPZ750 87 I believe, when I crank it over I see sparks around the #2cyclinder(inside one on the right side). These sparks are around the plug to cylinder. I know those is a short but does anyone got a place to start,
thanks
thanks
- mopguy
Re: GPZ750
09 Mar 2018 10:37 - 09 Mar 2018 10:45
Sitting on your bike, from left to right you have cylinders 1,2,3,4. Your left coil operates cylinders 2 & 3, right coil operates cylinders 1, 4 and firing order is 1,2,4,3. Check your high tension wires and caps, they may need replacement, or wires need to be nipped and and caps reinstalled.
www.wikihow.com/Test-Spark-Plug-Wires
Last edit: 09 Mar 2018 10:45 by mopguy.
