- Thank you received: 99
KZ Starters - Early 2-Brush vs. 4-Brush - Can I Convert?
- NakedFun
27 Feb 2018 18:21 #779510
by NakedFun
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
KZ Starters - Early 2-Brush vs. 4-Brush - Can I Convert? was created by NakedFun
Guys,
So I have a early 2-Brush starter in my KZ900. I know I can take the later model KZ1100 4-Brush model starter and bolts right in, no mods what so ever. So since I was planning on rebuilding my starter, the question is can I order a 4-brush rebuild plate/kit and slot it into my 2-brush starter? Anyone know this? Otherwise I will just order a 2-brush rebuild kit....
Cory
Cory
1976 Kawasaki KZ900
- Thank you received: 2068
27 Feb 2018 18:53 #779515
by Scirocco
Replied by Scirocco on topic KZ Starters - Early 2-Brush vs. 4-Brush - Can I Convert?
I would say no, different commutator (coil and spacing) on the rotor.
- NakedFun
27 Feb 2018 19:15 #779518
by NakedFun
1976 Kawasaki KZ900
Replied by NakedFun on topic KZ Starters - Early 2-Brush vs. 4-Brush - Can I Convert?
I agree that maybe a problem with the commutator design, but I noticed that the brush spacing on the 2 brush design is 90 degrees apart, and the 4 brush has two pairs set 90 degrees apart. So trying to remember when I used to play with electric motors and modify them as a kid..... anyway may just buy the 2 brush kit.
Cory
Cory
1976 Kawasaki KZ900
