Help with Anti Gravity battery
- JohnLuke
- 1982 KZ750N Spectre
27 Jan 2018 21:07
I’m thinking about getting a anti gravity battery for me 1982 kz750n spectre. The purpose would be, to clean up the battery box on custom build. It says on the site that i may need to upgrade my charging system due to an old rectifier overcharging a battery,
My question is, is that really nessesary to upgrade? If so what regulator rectifier would yall recommend?
Thanks!
Thanks!
Re: Help with Anti Gravity battery
29 Jan 2018 05:33 - 29 Jan 2018 06:03
I would get an SH mosfet voltage regulator from a modern motorcycle.
Do a search for mosfet. and type Nessism in the username box as he's actually made the upgrade.
Here's one topic I found from a quick search. there are many more.
KZR topic >>> Wiring in a MOSFET R/R
Last edit: 29 Jan 2018 06:03 by martin_csr.
- JohnLuke
29 Jan 2018 14:21
Would a Electrosport regulator rectifier work with the antigravity?
- DoctoRot
29 Jan 2018 22:02
Im running a Rick's motorsport electrics R/R with a ballistic battery and have had no problems
- McZed
30 Jan 2018 09:14
How many gigawatts is your flux capacitor?
