Please help, bike runs then engine cuts off!
- hard@lurk
26 Jan 2018 09:26 #777815
by hard@lurk
Please help, bike runs then engine cuts off! was created by hard@lurk
I have a 77 1000, I have had it for 7 years. The last year or so it will be running fine and start right up and run for weeks on end then will just die. Upon the bike shutting down, the electrical will still be on, but I can not get it to turn over again. The first time this happened I let It sit for a couple months out of frustration. I put new plugs in it, even though the old ones were not that old, and soaked the filter cones in some gas and dried them out and it turned right over, only to shut down again weeks later. Please help and any guidance is appreciated.
- KZQ
- Administrator
- Thank you received: 1415
26 Jan 2018 10:48 #777822
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic Please help, bike runs then engine cuts off!
Are you saying the bike quits or after you stop the engine it wont start again? If you're turning it off and then finding it wont turn over I'd look toward the starter connections, including solenoid and ground?
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- Thank you received: 2235
26 Jan 2018 12:31 #777828
by TexasKZ
Replied by TexasKZ on topic Please help, bike runs then engine cuts off!
I would also have the battery load tested to insure that there is not a dead cell:
- loudhvx
- Thank you received: 1616
26 Jan 2018 12:36 #777829
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Please help, bike runs then engine cuts off!
I always understood "turn over" meant the crankshaft was rotating, as in being turned by the starter motor. But I think younger people, or people who didn't grow up around working on cars/bikes etc., incorrectly take it to mean firing on it's own, as in starting to run, as opposed to merely being turned over by the starter motor.
There is a big difference between the two meanings. So is the starter not turning the crank? Or is the crank turning, but the engine isn't firing?
1981 KZ550 D1 gpz.
Other links.
- missionkz
26 Jan 2018 18:03 #777841
by missionkz
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Replied by missionkz on topic Please help, bike runs then engine cuts off!
“Turns over” is what you do with the kick starter, the starter motor, a wrench on the end of the crankshaft or any other means to turn the crankshaft over. Period.
Bruce
1977 KZ1000A1
- missionkz
26 Jan 2018 18:04 - 26 Jan 2018 18:05 #777842
by missionkz
Bruce
1977 KZ1000A1
Sorry... didn’t read the previous reply by Loud! Lolmissionkz wrote: “Turns over” is what you do with the kick starter, the starter motor, a wrench on the end of the crankshaft or any other means to turn the crankshaft over. Period.
Bruce
1977 KZ1000A1
Last edit: 26 Jan 2018 18:05 by missionkz.
