- Thank you received: 19
Brake Switch compatibility
- 650Dude
- Banned
22 Jan 2018 08:57 #777574
by 650Dude
1977 Kawasaki KZ650B
1977 Kawasaki KZ750 Twin
Brake Switch compatibility was created by 650Dude
Looking for a front and rear brake switch for my 1977 Kawasaki KZ750-B twin.
Are 650 - 1000 switches compatible/interchangeable? Im having a hard time finding any and Z1 has no phone and is slow to answer emails.
- Thank you received: 1656
22 Jan 2018 09:21 - 22 Jan 2018 09:24 #777575
by martin_csr
Replied by martin_csr on topic Brake Switch compatibility
Using the part numbers from Partzilla for the 77 750-B2, there are several new or nos listed on eebbaayy. and at reasonable cost if not cheap. The Fr br switch is in the Fr master cylider diagram. the rear is in the chassis-elec diagram.
Z1Enterprises lists several banjo bolt brake light switches that you could use in place of one of the banjo bolts on the front brake. look in the wheel & brake section for your bike.
Last edit: 22 Jan 2018 09:24 by martin_csr.
