1976 KZ650
- Bookem51
03 Nov 2017 11:16 #774164
by Bookem51
1976 KZ650 was created by Bookem51
Hello again. It seems this winter is bringing me into the world of Kawasaki lol.
Another one has rolled, or I should say carried piece by piece, into my shop. A 1976 KZ650. Parts have been cut off and misplaced over the years and I'm left with most of the frame, front end and engine. Seems like a good base for another custom. My question is, where do I find a wiring diagram for this girl? A bit of research indicates there might be a difference in the charging system for a 76. All the available manuals only seem to go back to 1977. All I need at the moment really is the basic wiring for the charging and ignition.
Thx for any help you can give.
Pics in the way soon.
- Thank you received: 2067
03 Nov 2017 12:52 - 03 Nov 2017 12:53 #774167
by Scirocco
Replied by Scirocco on topic 1976 KZ650
take a look into the service manual, page #220 and 221 for the KZ650 B1 1976-77
www.kzrider.com/modules/ServiceManuals/K...Service%20Manual.pdf
Check your frame and engine #
Source:
jarlef.no/Kawasaki/Series/Z/650/z650b.htm
Michael
Source:
Michael
Last edit: 03 Nov 2017 12:53 by Scirocco.
- Thank you received: 2829
03 Nov 2017 15:27 - 03 Nov 2017 15:31 #774177
by 650ed
Replied by 650ed on topic 1976 KZ650
There is no such thing as a 1976 KZ650 model. but there are 1977 KZ650 models that were built in the latter part of 1976. You need to base your repairs, parts order, etc. on the MODEL of the bike. So, if for example, you own a KZ650-B1 or a KZ650-C1 it is a 1977 model even though it may have been built in 1976. Think of it like a car. If you went out today and bought a 2018 Corvette it would have been built in 2017, otherwise you couldn't even see one until next year. Take a look at the frame number that is stamped in the steering stem neck, That will identify the model. Also, it is true that the KZ650-B1 and KZ650-C1 charging systems are different than those of any other year KZ650. Ed
Last edit: 03 Nov 2017 15:31 by 650ed.
